/6 distributor curve question |
tornik550 |
Apr 7 2017, 01:37 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I have a /6 2.7l with E cams. Should I base my distributor curve on the cams that I am using or the displacement? If you had my setup- would you go with a 2.2e distributor or a 2.7s distributor?
GeorgeRud |
Apr 7 2017, 03:34 PM
Does the 2.2 distributor fit in the 2.7 case? I thought they were different sizes.
tornik550 |
Apr 7 2017, 03:37 PM
GeorgeRud |
Apr 7 2017, 03:59 PM
On my 2.7 with an HPV-1 Clewitt ignition, we ended up with 8 degrees initial advance with an additional 25 degrees added at 3000 RPM, then no additional advance at 6000. I'm running RS pistons with S cams and Webers.
tornik550 |
Apr 7 2017, 04:06 PM
On my 2.7 with an HPV-1 Clewitt ignition, we ended up with 8 degrees initial advance with an additional 25 degrees added at 3000 RPM, then no additional advance at 6000. I'm running RS pistons with S cams and Webers. This may sound silly however was there any sort of a curve or was the advance 8 at all rpm til 3000 and all rpm above 3000 was 25? |
gereed75 |
Apr 7 2017, 05:16 PM
Senior Member Group: Members Posts: 1,249 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
Tornik There are a bunch of curves on line like these below.
http://forums.pelicanparts.com/porsche-911...-2-4-mfi-t.html Remember the rpm curves are based on distributor rpm - half the engine rpm. |
mb911 |
Apr 7 2017, 05:42 PM
914 Guru Group: Members Posts: 6,871 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I am pretty sure the 2.7 and down distributor Are interchangeable as far as fit.. That said the curves are all different..
GeorgeRud |
Apr 7 2017, 08:31 PM
The 25 degrees are added linearly to the initial 8 degrees. The HPV-1 does not have near the capabilities of more modern ignition systems, but has been reliable and simple.
porschetub |
Apr 9 2017, 12:43 AM
Advanced Member Group: Members Posts: 4,703 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Not sure so don't know what year was the reverse rotation dizzy 2.7 or later ?.
I have 2.4 MFI dizzy and have removed the vacuum retard can lock out the retard on the advance and run it as a a pure mechanical advance ,yet to fit so don't know should work,easier to get parts for than the Marreli besides. |
porschetub |
Apr 9 2017, 01:09 AM
Does the 2.2 distributor fit in the 2.7 case? I thought they were different sizes. The 2.2 doesn't fit the 2.7 case. I actually have a programmable distributor and I was just going to input the specs. Sorry failed to read your reply ,would you have said they needed machining down and changing the gear ?...just don't remember what I read a while back on this. |
mb911 |
Apr 9 2017, 06:39 AM
Not sure so don't know what year was the reverse rotation dizzy 2.7 or later ?. I have 2.4 MFI dizzy and have removed the vacuum retard can lock out the retard on the advance and run it as a a pure mechanical advance ,yet to fit so don't know should work,easier to get parts for than the Marreli besides. 3.0 |
Lo-Fi Version | Time is now: 31st May 2024 - 10:15 PM |
