Replace injectors now car won't stay running |
J123young |
Apr 8 2017, 06:33 PM
Member Group: Members Posts: 50 Joined: 1-February 17 From: Fenton, MO. Member No.: 20,801 Region Association: None |
So I replace all injectors with new gaskets and also replaced the fuel filter. I replaced the injectors because one was leaking.
Now car won't stay running...any ideas.? |
audio_file |
Apr 8 2017, 06:37 PM
Member Group: Members Posts: 295 Joined: 6-August 11 From: Everett, Wa Member No.: 13,409 Region Association: Pacific Northwest |
I found it frighteningly easy to plug the wires into the injectors backwards, double check that... if you replaced the fuel filter up under the fuel tank, check to make sure you didn't pinch a fuel line between the tank and the car body if/when you moved the tank.
injunmort |
Apr 8 2017, 08:47 PM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
i have an idea..... ljet, djet, motronic? any more info?
TheCabinetmaker |
Apr 8 2017, 09:07 PM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I found it frighteningly easy to plug the wires into the injectors backwards, double check that... if you replaced the fuel filter up under the fuel tank, check to make sure you didn't pinch a fuel line between the tank and the car body if/when you moved the tank. Makes no difference. They work either way. |
J123young |
Apr 9 2017, 04:36 PM
I found it frighteningly easy to plug the wires into the injectors backwards, double check that... if you replaced the fuel filter up under the fuel tank, check to make sure you didn't pinch a fuel line between the tank and the car body if/when you moved the tank. Thanks for the help. It was a pinched fuel line. |
Lo-Fi Version | Time is now: 31st May 2024 - 07:55 PM |
