Any idea what this engine is?, Little help |
Snebs2 |
Apr 12 2017, 07:33 PM
Newbie Group: Members Posts: 11 Joined: 7-April 16 From: Washington Member No.: 19,870 Region Association: Pacific Northwest |
Mark Henry |
Apr 12 2017, 07:51 PM
EC is a '74 1.8 engine code, but it's in the wrong place for a 914 so I'm going to say it's out of a VW 412.
Where's the dipstick located? |
Snebs2 |
Apr 12 2017, 09:19 PM
Well a picture worth a thousand words.
Attached thumbnail(s) |
Snebs2 |
Apr 12 2017, 09:22 PM
I decreased the engine and that was the only number I could find other than the ones on the transmission.
Mikey914 |
Apr 12 2017, 09:39 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
It's not a 2.0 (at least if stock).
Snebs2 |
Apr 12 2017, 09:53 PM
I should have said the car it's self is a 1972 but that's not to say this engine is...it was kinda a barn find hasn't been on the road since or tags since 1996.
porschefile2010 |
Apr 12 2017, 10:50 PM
Member Group: Members Posts: 228 Joined: 26-May 11 From: Whangaparaoa, New Zealand Member No.: 13,118 Region Association: Australia and New Zealand |
As near as I can tell, it's a 74 or 75 low compression, CA only 1.8 with F/I but I'm not sure they had four bolt intakes. That's got me thinking.
jcd914 |
Apr 12 2017, 11:07 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
The EC engines were 1.8 used in the 914 and 411/412.
The engine number location would seem to indicate this engine is from a 411/412. Also the dipstick tube looks to be covered with a hose? Possible spme me fabed a rubber dipstick tube to relocate it for use in the 914. 411/412 dipsticks were similar to buses and go down low by the front engine mount. All stock 1.7 & 1.8 engines used 4 bolt intakes as so did the 2.0 bus engines. 914/912E 2.0 were the only engines to use 3 bolt intakes. Jim |
Mark Henry |
Apr 13 2017, 05:32 AM
The EC engines were 1.8 used in the 914 and 411/412. The engine number location would seem to indicate this engine is from a 411/412. Also the dipstick tube looks to be covered with a hose? Possible spme me fabed a rubber dipstick tube to relocate it for use in the 914. 411/412 dipsticks were similar to buses and go down low by the front engine mount. All stock 1.7 & 1.8 engines used 4 bolt intakes as so did the 2.0 bus engines. 914/912E 2.0 were the only engines to use 3 bolt intakes. Jim (IMG:style_emoticons/default/rolleyes.gif) Like I said 1974 412, they didn't make a 411 in 1974. Why I also asked about the dipstick. I've seen the web site that says EC is a California only code, but it's wrong, my Canadian sold 1974 914 had an EC code engine with no smog pump. Look at the front of the engine case, right side bottom you will see a cover plate, big hole two bolts, likely homemade. |
Snebs2 |
Apr 13 2017, 06:56 PM
So it ran when I got it home ( smoked and had a miss) should rebuild or replace? Also I forgot to say it had dual carburetors that I had to take off to get the engine tins off. All I'm looking for is a good weekend driver.... still working on the body and most things 914 seem to have go wrong with them.
Thanks again for all the help from everyone. |
Lo-Fi Version | Time is now: 6th June 2024 - 07:03 AM |
