wtb early pressure regulator double banjo fitting, Need a couple of parts for brake system |
buck toenges |
Apr 17 2017, 12:44 PM
Senior Member Group: Members Posts: 553 Joined: 25-November 03 From: Fort wayne In Member No.: 1,388 Region Association: None |
I need the double banjo fitting from an early pressure regulator . Number 27 on the pet catalog. I also need the banjo bolt for that fitting.
I also need the 90 degree brass fitting (number 15) that goes from the brake line through the tunnel to the line that connects to the bottom of the early pressure regulator. Thanks, Buck |
914Sixer |
Apr 18 2017, 09:32 PM
914 Guru Group: Members Posts: 8,909 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Might have the 90 degree fitting, check tomorrow.
Lo-Fi Version | Time is now: 15th June 2024 - 08:13 PM |
