Noooooo! My car will now not make it to Hershey..., Help!! |
dudzy's914 |
Apr 19 2017, 09:39 AM
The youngin' Group: Members Posts: 271 Joined: 21-December 13 From: Hatfield, MA Member No.: 16,784 Region Association: North East States |
So I am getting ready for the drive on Friday, have Tangerine do some adjustmensats, drive it home and now it's on 3 cyclinders. Quickly got new plugs/wires/cap and rotors and still only on 3. Spark plug 1 was black and spark plug 2 was wet with gas. Anything else I can do?
BillC |
Apr 19 2017, 09:51 AM
Senior Member Group: Members Posts: 546 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
Is it carbureted or fuel-injected? Still using points & condenser or converted to electronic ignition?
Have you tried inspecting the spark plugs? You might have a bad one. If you can't see anything obvious, try switching two plugs and see if the problem follows the plug or stays with the cylinder. Also, have you inspected the points in the distributor? Maybe they weren't tightened properly and need re-adjustment. |
dudzy's914 |
Apr 19 2017, 10:24 AM
Is it carbureted or fuel-injected? Still using points & condenser or converted to electronic ignition? Have you tried inspecting the spark plugs? You might have a bad one. If you can't see anything obvious, try switching two plugs and see if the problem follows the plug or stays with the cylinder. Also, have you inspected the points in the distributor? Maybe they weren't tightened properly and need re-adjustment. Fuel Injected l-jet. Replaced the spark plugs to see if that was the problem-nope, not it. brand new points and condenser. |
cgnj |
Apr 19 2017, 03:09 PM
Senior Member Group: Members Posts: 627 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None |
Hi,
Pullplug wires one @ a time to find out which hole is bad. Pull plug from bad hole. Check for spark. I hate tossing parts @ a problem. |
PotterPorsche |
Apr 19 2017, 03:24 PM
Member Group: Members Posts: 295 Joined: 10-November 13 From: Hayward CA Member No.: 16,628 Region Association: None |
I had same issue my dirtibutir cap was old and corroded inside. Replaced fouled spark plug and distributor cap and rotor. Ran fine the next day at autocross
VaccaRabite |
Apr 19 2017, 07:09 PM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
He knows exactly which cylinder is bad. Its #2.
Do a compression test on the bad cylinder. That will tell you if the problem is mechanical. Ground the plug against the engine block and watch for spark. That will test electrical. Pull the injector and spray it into a jar. make sure it sprays and not drips. That will test fuel delivery. I'm assuming that the car is running rough but it is not making other bad noises. Zach |
Rand |
Apr 19 2017, 07:36 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
He knows exactly which cylinder is bad. Its #2. Do a compression test on the bad cylinder. That will tell you if the problem is mechanical. Ground the plug against the engine block and watch for spark. That will test electrical. Pull the injector and spray it into a jar. make sure it sprays and not drips. That will test fuel delivery. I'm assuming that the car is running rough but it is not making other bad noises. Zach (IMG:style_emoticons/default/agree.gif) If you don't have a compression tester, start with the spark test. Pull plug wire #2, stick a plug in it, ground its threads to the case, and watch for spark when someone cranks it. I love the tests that only take a minute but tell a lot. |
ChrisFoley |
Apr 20 2017, 04:41 AM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I spoke with Finn late yesterday.
He did some diagnostics at my suggestion. The engine does run, but barely, and the problem doesn't seem to be isolated to one cylinder. Since the car needs a clutch anyway its an easy decision to back out of taking it to Hershey. |
Lo-Fi Version | Time is now: 8th June 2024 - 01:36 AM |
