john77 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California ![]() ![]() |
My lid alignment was a mess so I inspected the hinge mounts and found both had cracked welds. I re-welded them, put the lid back on, and the alignment was still a mess.
It's a GT style lid and I figured the force of the torsion bars was too much causing it to twist when fully shut, so I removed them and it fits perfectly. Only problem is, now it won't stay open on its own. Anyone have an ingenious solution to this? Simple metal prop attached to the lid? Small shock? Hydraulic air lift set up with nitrous oxide? Thanks John |
GregAmy |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,311 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States ![]() ![]() |
On the race car I removed the hinges and the latch entirely and have it held on with three hood pins. Makes it REAL easy to work on the car...you may not want to do this, but if you do...
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1201.photobucket.com-15565-1493678536.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1201.photobucket.com-15565-1493678536.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1201.photobucket.com-15565-1493678537.3.jpg) |
amfab |
Member ![]() ![]() Group: Members Posts: 393 Joined: 17-May 16 From: Los Angeles Member No.: 20,004 Region Association: None ![]() ![]() |
Maybe bend up a copy of the torsion bar with thinner diameter rod?
Marv's3.6six |
Actual member 7" ![]() ![]() ![]() Group: Members Posts: 695 Joined: 22-November 04 From: Huntington Beach, Ca. Member No.: 3,165 Region Association: Southern California ![]() ![]() ![]() |
It's a GT style lid and I figured the force of the torsion bars was too much causing it to twist when fully shut, so I removed them and it fits perfectly. Only problem is, now it won't stay open on its own. The GT style lid is very light weight.... so with the standard 2 torsion springs it way over powers the lid. I found using just one of the torsion springs was sufficient. The GT lid is also pretty flimsy so it is easy to twist the lid itself to make it line up. Mine was easy peasy. |
john77 |
It's a GT style lid and I figured the force of the torsion bars was too much causing it to twist when fully shut, so I removed them and it fits perfectly. Only problem is, now it won't stay open on its own. The GT style lid is very light weight.... so with the standard 2 torsion springs it way over powers the lid. I found using just one of the torsion springs was sufficient. The GT lid is also pretty flimsy so it is easy to twist the lid itself to make it line up. Mine was easy peasy. I actually already tried this and even one puts it out of shape. My lid is 'GT-lite' though - I bought the frame trimmed back to almost nothing and finished it myself by just wrapping it in expanded aluminum. It looks good but has zero structural rigidity. |
tygaboy |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,314 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California ![]() ![]() |
I got this for my LS build. Haven't installed it yet...
http://www.patrickmotorsports.com/part/eng...t-set-body-914/ |
john77 |
john77 |
I got this for my LS build. Haven't installed it yet... http://www.patrickmotorsports.com/part/eng...t-set-body-914/ Thanks Tyga. This is kind of what I had in my head. Where does it attach? |
john77 |
On the race car I removed the hinges and the latch entirely and have it held on with three hood pins. Makes it REAL easy to work on the car...you may not want to do this, but if you do... (IMG:http://www.914world.com/bbs2/uploads_offsite/i1201.photobucket.com-15565-1493678536.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1201.photobucket.com-15565-1493678536.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1201.photobucket.com-15565-1493678537.3.jpg) Nice solution Greg. Not quite right for me, but it looks great. |
Lucky9146 |
Always Wanted A Bigger Go Cart ![]() ![]() ![]() Group: Members Posts: 1,621 Joined: 22-September 14 From: Poway California Member No.: 17,942 Region Association: Southern California ![]() ![]() |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
It's a GT style lid and I figured the force of the torsion bars was too much causing it to twist when fully shut, so I removed them and it fits perfectly. Only problem is, now it won't stay open on its own. The GT style lid is very light weight.... so with the standard 2 torsion springs it way over powers the lid. I found using just one of the torsion springs was sufficient. The GT lid is also pretty flimsy so it is easy to twist the lid itself to make it line up. Mine was easy peasy. Good info,would one torsion bar be enough for a standard six conversion lid ? i.e. less rain tray etc. The gas strut is a solution but it does intrude into the engine space somewhat and its about finding the right one...too much tension and the lid twists as mentioned. |
tygaboy |
I got this for my LS build. Haven't installed it yet... http://www.patrickmotorsports.com/part/eng...t-set-body-914/ Thanks Tyga. This is kind of what I had in my head. Where does it attach? Here's a pic from the PMS site. But there are a bunch of ways/places I bet would work. Attached image(s) ![]() |
Marv's3.6six |
That might be a problem... (IMG:style_emoticons/default/blink.gif) Good info,would one torsion bar be enough for a standard six conversion lid ? i.e. less rain tray etc. Have seen it done but the lid only pops up a few inches. Still the same issue in that the lid will need some help to stay all the way open. |
porschetub |
I actually already tried this and even one puts it out of shape. My lid is 'GT-lite' though - I bought the frame trimmed back to almost nothing and finished it myself by just wrapping it in expanded aluminum. It looks good but has zero structural rigidity. That might be a problem... (IMG:style_emoticons/default/blink.gif) Good info,would one torsion bar be enough for a standard six conversion lid ? i.e. less rain tray etc. Have seen it done but the lid only pops up a few inches. Still the same issue in that the lid will need some help to stay all the way open. Thank you ,it will stay as it is, (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 03:54 PM |
