Wheel value? | vintage centerlines... |
litesonic |
May 4 2017, 07:22 PM
Newbie Group: Members Posts: 17 Joined: 8-January 15 From: Fort Collins CO Member No.: 18,307 Region Association: None |
Based on my research, these are old school centerlines.
Before I post for sale... what value do you think they have? Specs: 4x130 15x5.5 With 195 60 tire 32.5 lbs. thanks! Attached thumbnail(s) |
Tom_T |
May 4 2017, 07:29 PM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
They may not be 914 offset, which should be ET40.
If a VW offset, then you'll have better luck over at TheSamba.com with the VW folks (Porsches are over there too). From your pic of one, it's been curbed & looks to have some oxidation damage around the center, so based on what other aftermarket wheels go for in better shape - you may only be looking at $100-200 for the set of 4. PS ... maybe $300 if the tiers are a year or so off date code. For a real ad, you'll need the offset & good pix front & back of all wheels, & I suggest that you spend some elbow grease to thoroughly clean them up to eliminate any dirt looking like oxidation or damage, if you want top dollar. PS "Barum" isn't a top tire brand - more of an econo tire, & the age will also be a factor in whether they're still driveable, so show pix of the DOT date code on each tire & tread + sidewalls both sides' condition for any cracking. GLWTS! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Mueller |
May 4 2017, 07:33 PM
Centerline wheels or just a Centerline cap on those wheels?
Knowing offset helps, might be too close to outer fender on the rear for some people. I'd say $200 for the wheels only, $350ish for complete combo if tires are in good shape and not past expiration date. Nothing special about the size and if only 4 of them one has to consider the risk they are taking in buying a set of wheels that you don't see too often. All it takes is a flat tire or something to damage a wheel and until you find a replacement you have nothing but scrap metal |
arne |
Serial Rescuer of old vehicles... Group: Members Posts: 741 Joined: 31-January 17 From: Eugene, Oregon Member No.: 20,799 Region Association: None |
The center caps are Centerline, the wheels are not. I can't recall for sure who made that particular wheel (my wheel sales career was a long time ago, from '75-98). I think it was Western Wheel.
litesonic |
May 4 2017, 07:46 PM
Thorough and thoughtful reply Tom... big thanks.
My question was really both to determine the potential value and weigh the amount of effort to clean up the other three. They are from a "barn find" 914 and look the part (see attached pic). They fit the arches nicely (pictured on their original shot 165) The tires are 3.5 years old according to the DOT code. But that's my doing.. and frankly I only mounted them so I could move the car while working on it. The previous had perished. Hmmm. Well I know new centerline caps will run me $125... so this seems a wash at best |
KELTY360 |
May 4 2017, 08:58 PM
914 Neferati Group: Members Posts: 5,034 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
They look like BBS wheels.
Mueller |
May 4 2017, 09:17 PM
I think they would look better with shorter center caps, those stick out too far.
Make you when you list them to include the lug bolts since standard 914 lug bolts will not work with those wheels. |
arne |
May 4 2017, 09:31 PM
Found them. Not Westerns, they are Ansen Cross Wires. Not sure when I've last seen real Ansen caps, so use whatever you find that fits.
http://www.akhwheels.com/pages/showWheel.php?pk=935 |
litesonic |
May 5 2017, 12:50 AM
Found them. Not Westerns, they are Ansen Cross Wires. Not sure when I've last seen real Ansen caps, so use whatever you find that fits. http://www.akhwheels.com/pages/showWheel.php?pk=935 wow.. ok. I thought they were centerlines... Now I see they are even more obscure. |
litesonic |
May 5 2017, 01:00 AM
Found them. Not Westerns, they are Ansen Cross Wires. Not sure when I've last seen real Ansen caps, so use whatever you find that fits. http://www.akhwheels.com/pages/showWheel.php?pk=935 wow.. ok. I thought they were centerlines... Now I see they are even more obscure. Yeah even those use the american racing hubcap... stange |
litesonic |
May 5 2017, 08:14 AM
And those are 14 not 15... I can't find another set of these anywhere.
arne |
May 5 2017, 09:01 AM
Back in the '70s, all Centerline wheels were spun aluminum, not cast. Also, in those days many different wheel manufacturers used a fairly standard size center hole, so many center cap brands were interchangeable.
Yes, among old time wheel companies that bothered to make wheels at all for VW and 914, the proper and narrow 15" sizes were not common even back then. So finding a decent set of 4 today is unusual. That said, I don't know that their rarity makes them especially valuable, even when the supply is tight, there needs to be some demand for them. They are probably worth cleaning up if it can be done without too much time invested. I'd probably try to sell them on Samba though, as I suspect there may be more interest from VW owners, and you won't want to limit your market. |
litesonic |
May 5 2017, 03:41 PM
Back in the '70s, all Centerline wheels were spun aluminum, not cast. Also, in those days many different wheel manufacturers used a fairly standard size center hole, so many center cap brands were interchangeable. Yes, among old time wheel companies that bothered to make wheels at all for VW and 914, the proper and narrow 15" sizes were not common even back then. So finding a decent set of 4 today is unusual. That said, I don't know that their rarity makes them especially valuable, even when the supply is tight, there needs to be some demand for them. They are probably worth cleaning up if it can be done without too much time invested. I'd probably try to sell them on Samba though, as I suspect there may be more interest from VW owners, and you won't want to limit your market. Excellent advice, thanks! I think I may just hang onto them and spend money on other things. I do wish I had the original 2.0 liter fuchs, but that may have to wait for a while. They are round and hold the tires... I don't need more right now. |
thelogo |
May 5 2017, 04:13 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
300 bucks tops
Thats what id pay for em But im a long lost decedent of the cheap sob |
Lo-Fi Version | Time is now: 1st June 2024 - 05:32 PM |
