| steuspeed |
May 5 2017, 09:42 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,011 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
Installed Hella supertone horns. Plug and play. They came with a relay. I did not use it. Maybe install later?
Attached thumbnail(s) |
| ConeDodger |
May 5 2017, 10:25 PM
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,390 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California
I have a set that I need to install as well. The hold up is, mine is a '75. I want to relocate the horns to behind the bumper. Need to have McMark weld flange nuts in there to mount them.
How do they sound? (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/w00t.gif) |
| 914dave |
May 6 2017, 06:12 AM
914 Addict ![]() ![]() ![]() Group: Members Posts: 740 Joined: 19-October 03 From: Willow Grove Pa. Member No.: 1,262 Region Association: North East States
They are loud! 118 decibels. I thought mine was disconnected when I first energized the car. No ground wire. The ground wire must have been touching the hub. I reached thru the steering wheel to test the starter and hit the horn. Scared the crap out of me!!!
Inside a closed 20 x 20 garage. It will get people's attention. |
| GeorgeRud |
May 6 2017, 07:08 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
I put some on my 911, and am very impressed with the tone and volume they produce. I am planning on installing a set on my conversion car as well since I think that a loud horn and a high mounted third brake light are now required equipment to survive on today's roadways. I'm also searching how to use the fog lights as daytime running lights by somehow fitting them with LEDs. Anything to make the car more visible (besides the bright yellow paint).
| Tjmrfe |
May 6 2017, 08:13 AM
NON IMPEDING RATIONE COGITATIONIS ![]() ![]() Group: Members Posts: 132 Joined: 10-April 15 From: Cornwall on Hudson, New York Member No.: 18,612 Region Association: North East States |
They are loud! 118 decibels. I thought mine was disconnected when I first energized the car. No ground wire. The ground wire must have been touching the hub. I reached thru the steering wheel to test the starter and hit the horn. Scared the crap out of me!!! Inside a closed 20 x 20 garage. It will get people's attention. Hey, nice car color....and I just purchased a set of these from Amazon....am hoping they have that "euro" "bleet-bleet" Sound, will return them if it sounds like a Camry... (IMG:style_emoticons/default/blink.gif) |
| Olympic 914 |
May 6 2017, 08:50 AM
![]() ![]() ![]() Group: Members Posts: 1,771 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States
I got a set of the Hella Sharptones. haven't mounted them yet either.
They have the yellow grills, think I will paint them flat black before I install them though. |
| DRPHIL914 |
May 6 2017, 10:17 AM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,907 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
I also bought these last month but I have not installed them. mine is a 75 too,
and maybe more complicated because the p.o. put in an airhorn and has some crazy wiring that I hope I can back trace where they ran the wiring and relay for the airhorn where its located up under the drivers side cowl. I do need to get this done tho, too much traffic around here and I need to be able to get their attention when they start to run me off the road! ive had a couple close calls recently (IMG:style_emoticons/default/mad.gif) glad to hear they are loud! |
| orthobiz |
May 6 2017, 02:22 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,762 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest
I assume they fit under the grilles....???
Paul |
| ConeDodger |
May 6 2017, 04:58 PM
| jim_hoyland |
May 6 2017, 05:11 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,040 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
Are these Hellas made in Germany ?
| GeorgeRud |
May 6 2017, 07:23 PM
I don't think so anymore. There is a YouTube video where the fellow compares the horn's sound. The red Supertones have a different sound than the yellow Sharptones.
| 914dave |
May 7 2017, 07:31 AM
| VaccaRabite |
May 8 2017, 09:29 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,845 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
Use the relay!
Cant stress this enough. I put mine on without the relay, an then wired in the relay with a wire that went right to the battery with an inline fuse. The difference is HUGE. The horns just draw more power then the stock horns, and your existing harness will be a bottleneck. Zach |
| DRPHIL914 |
May 8 2017, 10:10 AM
Use the relay! Cant stress this enough. I put mine on without the relay, an then wired in the relay with a wire that went right to the battery with an inline fuse. The difference is HUGE. The horns just draw more power then the stock horns, and your existing harness will be a bottleneck. Zach i think that is what my can has with the existimg aftermarket airhorn, would make it easier when i put these in, i should be able to use wiring thst is there- it has a relay next to horn. hm might be easier thanni thought |
| VaccaRabite |
May 8 2017, 09:02 PM
(IMG:http://www.914world.com/bbs2/uploads_offsite/c2.staticflickr.com-1435-1494298941.1.jpg) You can see how I mounted mine. With the supertones, they are directional horns. They are a lot louder in the direction they are facing. So if they are placed facing towards the street, or off to the side, you are going to loose some of their effectiveness. Also, if you don't use the relay, my experience is that the horns are not very loud, and they sound almost like they are winding up. With the relay, and a fat gauge wire that goes to the battery to feed them, they are instantly LOUD. Which is what you want in a horn. Mine make the people in front of me jump when I use them. Zach |
| oakdalecurtis |
May 8 2017, 10:13 PM
Oakdalecurtis ![]() ![]() ![]() Group: Members Posts: 1,403 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California
The stock horn already has a relay, why would a second relay be necessary? If the wire to the factory horn is too light, couldn't you just increase that wire from the existing relay to the new horns?
| VaccaRabite |
May 9 2017, 09:42 AM
The stock horn already has a relay, why would a second relay be necessary? If the wire to the factory horn is too light, couldn't you just increase that wire from the existing relay to the new horns? You could, and maybe it would work just fine. But it does not run to the battery directly (IIRC), and that would be a lot of harness unwrapping to get to the wire in question. Its a LOT easier to just run a new wire, and a lot easier to pull that wire out if you want to go back to stock later. Zach |
| DRPHIL914 |
May 10 2017, 08:32 PM
put mine in today! passenger side was easy, plug and play.
not so easy on drivers side the nut holding it on was rusted pretty bad , snapped off- but not to get into too much detail, its mounted. i ised existing wiring- but in front trunk i had to reattach the wire to drivers side and the p.o. cut it tonwire up am air horn, but back to theway it should be now! rifht now im just rumning off thr original relay, and its very loud! nit sure why i would wite ina second relay |
| McMark |
May 11 2017, 07:05 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
(IMG:style_emoticons/default/av-943.gif) I had a dream about this thread last night. I was driving the 914 and had to honk at a crazy driver, but the honk that came out was pitiful, like a kitten's meow. And in my dream I remember thinking, "I'd better read that thread about the SuperTone horns, and install a set...."
Get outta my head 914World!!!! |
| LowBridge |
May 11 2017, 08:05 AM
Member ![]() ![]() Group: Members Posts: 370 Joined: 10-August 15 From: Lunenburg, MA Member No.: 19,045 Region Association: North East States |
I have mine mounted behind the 75 bumper without any issues... simple
(IMG:http://www.914world.com/bbs2/uploads_offsite/i219.photobucket.com-19045-1494511502.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i219.photobucket.com-19045-1494511502.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i219.photobucket.com-19045-1494511502.3.jpg) |
Lo-Fi Version | Time is now: 27th March 2026 - 04:32 AM |
