MPS reinstall |
MPS reinstall |
87m491 |
May 7 2017, 02:29 PM
Member Group: Members Posts: 275 Joined: 29-July 12 From: Portland, the original! Member No.: 14,731 Region Association: North East States |
Have just done the whole soft fuel system soup to nuts and I am buttoning up the engine compartment. I went to remount the MPS and the service port on the fuel rail is hitting the MPS body dead center.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i723.photobucket.com-14731-1494188982.1.jpg) The fuel elbows to the injectors are new and not as pliable as the originals, though a fair bit shorter so any interference should have been less than with the originals. Any one else run into this? Tilting the rail forward or back does not seem to help much as this port hits right in the widest portion of the MPS. Now I know why them MPS only had the top bolt properly installed and sheet metal screws in the bottom two holes. |
914_teener |
May 7 2017, 02:44 PM
914 Guru Group: Members Posts: 5,201 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
I think that fuel rain goes on the driver side not the passenger side IIRC.
Also...it's easier to put the screws in first and then slip the MPS into it. Then getting to the bottom one is a PITA. |
saigon71 |
May 7 2017, 02:57 PM
Advanced Member Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
The rail is on the correct side.
It's tight in there! I recommend using the pre-formed fuel injection hoses on the passenger side instead of simply using regular FI hose. It will give you a little more room. Even using them, I only have about 1/8" of clearance between that fuel rail bolt and my MPS. |
JeffBowlsby |
May 7 2017, 03:24 PM
914 Wiring Harnesses Group: Members Posts: 8,524 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Factory photo does not show the fuel pressure gauge port on the passenger side. It does not conflict with the MPS when its on the drivers side.
Attached image(s) |
914_teener |
May 7 2017, 03:33 PM
914_teener |
May 7 2017, 03:50 PM
87m491 |
May 7 2017, 03:59 PM
Whoa, that is one busy engine compartment with FP regulator and MPS on the same side. To be clear on my car the test port is factory blocked off AFAIK. Car is a 74 2.0. The port on the drivers side rail is open and feeds the cold start injector. Might be worthwhile to find a VW unit with no port at all to grab 10mm of space.
914_teener |
May 7 2017, 04:17 PM
On the 1.7's the port is on the end of the fuel rail on the drivers side and the CS injector is teed from the middle of the feed line.
Not so sure that what you have is the correct fuel rail. Give Bruce Stone a PM he has them all plated and blinged up. |
914_teener |
May 7 2017, 04:20 PM
Whoa, that is one busy engine compartment with FP regulator and MPS on the same side. To be clear on my car the test port is factory blocked off AFAIK. Car is a 74 2.0. The port on the drivers side rail is open and feeds the cold start injector. Might be worthwhile to find a VW unit with no port at all to grab 10mm of space. FP regulator is on the driver side in the pic I posted it is on the right side. |
JeffBowlsby |
May 7 2017, 04:28 PM
Whoa, that is one busy engine compartment with FP regulator and MPS on the same side. To be clear on my car the test port is factory blocked off AFAIK. Car is a 74 2.0. The port on the drivers side rail is open and feeds the cold start injector. Might be worthwhile to find a VW unit with no port at all to grab 10mm of space. That's not a FP regulator above the MPS...take another guess what it is. |
iankarr |
May 7 2017, 04:40 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,480 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Decel valve?
JeffBowlsby |
May 7 2017, 04:49 PM
iankarr |
May 7 2017, 04:58 PM
914_teener |
May 7 2017, 05:01 PM
Jeff....you are much nicer than I am.
iankarr |
May 7 2017, 05:05 PM
saigon71 |
May 7 2017, 08:10 PM
Interesting...
I've got nipples on both my fuel rails. The drivers side is connected to the FI system - cold start valve? I've always used the passenger side to check fuel pressure. |
jcd914 |
May 7 2017, 09:59 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
With a couple of wire ties around the intake runners and the fuel rail you can gently pull the fuel rail toward the intake runners and away from the MPS. Watch the injector elbows, you don't want to kink the hose and you don't want too much tension on the injectors.
Jim |
87m491 |
May 8 2017, 07:19 AM
Not too much give on the relatively short, and stiff new lines. I will try again. I think it might be easier to find another rail without the port. Surprisingly, I have not find a VW site that lists them yet....
With a couple of wire ties around the intake runners and the fuel rail you can gently pull the fuel rail toward the intake runners and away from the MPS. Watch the injector elbows, you don't want to kink the hose and you don't want too much tension on the injectors. Jim |
bdstone914 |
May 8 2017, 07:34 AM
bdstone914 Group: Members Posts: 4,531 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
To my knowledge all Type IV injected engines used one rail with a port and one without.
I have many fuel rails but only those with ports are left, no rails without the test port. |
BillC |
May 8 2017, 08:01 AM
Senior Member Group: Members Posts: 546 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
87m491 --
According to the diagram here: http://www.pelicanparts.com/914/technical_...4_20FI_diag.htm , the '74 2.0 looks like it is supposed to have test ports on both fuel injector rails, with the driver's side test port feeding the cold start valve. Check both rails, and see if one of the test ports is off-center. If so, that may be the one that is supposed to go on the passenger side. I'm just guessing, since I've never been that deep into a '74's engine compartment. Also, when I re-did the fuel lines on my '73, the MPS bracket was held in with one machine screw on top and two sheet metal screws on the bottom. So yours may have been mounted correctly. Are there any wear marks on your MPS, where the test port plug may have been rubbing before? Edit: just had a thought: Are the new fuel injector elbows taller than the old ones you took off? Maybe you can trim the new elbows down to lower the rail and get the clearance you need. |
Lo-Fi Version | Time is now: 1st June 2024 - 01:44 PM |
