Engine Stand - Flywheel - Vice - SF Area Shop |
sketchc13 |
May 13 2017, 10:07 PM
Newbie Group: Members Posts: 13 Joined: 7-February 11 From: NorCal Member No.: 12,675 Region Association: Northern California |
I'm looking for the following:
- workbench mounted engine stand - vice - credible SF Bay shop that can do head work (valve seat and guide replacement, port/polishing) - Lightened flywheel Any help is much appreciated! Cheers, Andrew |
iankarr |
May 14 2017, 01:03 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,480 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Shouldn't be too hard to find Vice and head work in the SF area...(IMG:style_emoticons/default/smile.gif)
Dominic |
May 14 2017, 02:41 PM
Dominic Group: Members Posts: 992 Joined: 14-January 03 From: Vacaville, CA Member No.: 149 Region Association: Northern California |
I'm looking for the following: - workbench mounted engine stand - vice - credible SF Bay shop that can do head work (valve seat and guide replacement, port/polishing) - Lightened flywheel Any help is much appreciated! Cheers, Andrew Andrew, For the head work, you should ask Dave Bonbright @ Engine Masters, he has a small shop (in his garage) in Sonoma, his number is (707) 938-8122. He's been doing Air Cooled Porsche and VW Machining for almost 50 years. Cheers, Dominic |
Mueller |
May 14 2017, 02:47 PM
I'm looking for the following: - workbench mounted engine stand - vice - credible SF Bay shop that can do head work (valve seat and guide replacement, port/polishing) - Lightened flywheel Any help is much appreciated! Cheers, Andrew Andrew, For the head work, you should ask Dave Bonbright @ Engine Masters, he has a small shop (in his garage) in Sonoma, his number is (707) 938-8122. He's been doing Air Cooled Porsche and VW Machining for almost 50 years. Cheers, Dominic Dominic, Do you remember a guy that did heads near the San Jose Airport, had a small shop in an industrial park, used an old manual Bridgeport mill for doing the heads. I want say his 1st name is John or Dave? I think Bugformance was just a few blocks away. |
Lo-Fi Version | Time is now: 2nd June 2024 - 03:44 PM |
