Ignition switch wiring, Rewiring 1975 ignition key/etc |
chewy71 |
May 18 2017, 07:33 PM
Newbie Group: Members Posts: 16 Joined: 16-July 08 From: newjersey Member No.: 9,310 Region Association: None |
Hi, my 1975 ignition was bypassed with a pushstarter and a toggle switch. I bought the parts I think I need to return it to a keyed ignition but I am having trouble with the wiring. Does anyone have a wiring diagram for a 1975 ignition or some helpful photos you can share.
Is the 1975 the same as the 1974? Are there any differences in the years? Thanks in advance for any assistance. chew |
jim_hoyland |
May 18 2017, 07:43 PM
Get that VIN ? Group: Members Posts: 9,320 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
From a '75....
Attached image(s) |
chewy71 |
May 18 2017, 07:49 PM
chewy71 |
May 26 2017, 06:20 AM
From a '75.... Jim, thanks for the incredibly quick response. Amazing support on this site. Does anyone know if the black connector is available in the market anywhere? I am assuming I need to get it from a salvage yard if I can find one.. When the car was modified one side was apparently thrown out and Soldering to the connector is not a good solution. |
jim_hoyland |
May 26 2017, 07:24 AM
From a '75.... Jim, thanks for the incredibly quick response. Amazing support on this site. Does anyone know if the black connector is available in the market anywhere? I am assuming I need to get it from a salvage yard if I can find one.. When the car was modified one side was apparently thrown out and Soldering to the connector is not a good solution. I had looked too; ended up using part of a wiring harness I picked up at a swap meet |
mepstein |
May 26 2017, 04:06 PM
914-6 GT in waiting Group: Members Posts: 19,316 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
The 12 pin connector? They are available new.
jim_hoyland |
May 26 2017, 09:04 PM
You mean this connector ?
Attached image(s) |
chewy71 |
May 28 2017, 08:34 PM
jim_hoyland |
May 29 2017, 05:48 AM
Try a WTB ad in the classified forum. You can cop/paste the image connector into the ad.
JeffBowlsby |
May 29 2017, 09:14 AM
914 Wiring Harnesses Group: Members Posts: 8,535 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Its PN 111.953.631
Google it to find sources. |
jim_hoyland |
May 29 2017, 01:31 PM
914work |
May 29 2017, 04:06 PM
Member Group: Members Posts: 291 Joined: 9-November 11 Member No.: 13,762 Region Association: None |
or right here (IMG:style_emoticons/default/biggrin.gif) POST
chewy71 |
Jun 5 2017, 10:06 PM
So car is all back together. Was busy with work so a friend of mine took care of it for me. Car starts and runs great. However, headlights won't go up. If I turn the lights on and press the break, the red and green light go on and everything is powered, with the key off. So if I turn the car off with my foot on the break and the lights on the car runs till I take ny foot off the brake. Obviously I screwed up. the plug I used was from a 1975 and the wire ccolors matched. Assuming I gave him the wrong year plastic switch. Mine car is a 1975, I had 2 one for a 1974 and one for a 1975. Gonna take it apart again and switch them. I am hoping this fixes the problem. thanjs for the parts help everybody. Back to the drawing board tomorrow. |
Lo-Fi Version | Time is now: 11th June 2024 - 04:06 AM |
