Impeller balancing ?, Stock or jury-rigged ? |
pgollender |
May 23 2017, 08:23 PM
Member Group: Members Posts: 193 Joined: 5-July 11 From: Sacramento Member No.: 13,281 Region Association: Northern California |
Cleaning and painting my impeller fan and noticed a little counter-balance weight pinned in the front. Factory job or P.O. attempt to balance the fan ?
All the blades are intact, no broken fins. |
rgalla9146 |
May 24 2017, 06:13 AM
Advanced Member Group: Members Posts: 4,569 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Probably original, I've seen bigger pieces of rod than that used in the same way.
McMark |
May 24 2017, 06:41 AM
And now your fan is unbalanced. (IMG:style_emoticons/default/sad.gif)
6freak |
May 24 2017, 06:50 AM
MR.C Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest |
just gonna say I hope you marked some how ,it needs to go back together the same way it came apart and still may need to rebalance....easy fix! imo good luck (IMG:style_emoticons/default/smile.gif) |
pgollender |
May 24 2017, 07:48 AM
bbrock |
May 24 2017, 08:51 AM
Do these have to be balanced at a machine shop? I have one I took apart thirty years ago and THINK I was careful to put it back together properly. But I would like to make sure before putting it back in service.
pgollender |
May 24 2017, 09:16 AM
Do these have to be balanced at a machine shop? I have one I took apart thirty years ago and THINK I was careful to put it back together properly. But I would like to make sure before putting it back in service. You can do a simple static balance that will get you close,but not as good as a dynamic balance. Luckily these little fan don't have a lot of rotating weight.: Get one of these nose cones on the video and don't cut but add: https://www.youtube.com/watch?v=uCV9rGVprEses |
Lo-Fi Version | Time is now: 9th June 2024 - 09:55 AM |
