How do GT headlights function? |
csdilligaf |
May 24 2017, 07:05 PM
Member Group: Members Posts: 106 Joined: 18-April 12 From: San Diego CA Member No.: 14,397 Region Association: None |
I have never seen them in action. Does the cable release a catch that allows them to pop open? Do they open slowly with the nitrogen piston or is it like a snap open? How do they get back down? Do you have to push them back down by hand? Or does the cable pull them back down?
tygaboy |
May 24 2017, 07:16 PM
914 Guru Group: Members Posts: 5,323 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
I've not seen them in action but yes, pull cable to release the catch and the hydraulics pop them open. (not sure how fast/hard). You have to close them by hand.
Here's a great place to learn all about it: http://www.pbase.com/9146gt/gt_mechanical_headlight_raisers |
ConeDodger |
May 25 2017, 08:55 AM
Apex killer! Group: Members Posts: 23,621 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Properly adjusted, you pull a release handle on the dash and they pop up. Your headlight switch only turns on and off the light. There are pictures in my project thread somewhere. I'll see if I can find them...
Just Another Damned Project Thread |
ConeDodger |
May 25 2017, 09:13 AM
Attached image(s) |
7TPorsh |
May 25 2017, 09:16 AM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
I like this idea...here may be a way to make the lights pop open half way and put some low profile led lights.
VaccaRabite |
May 25 2017, 09:29 AM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
VaccaRabite |
May 25 2017, 09:30 AM
Someone also had a push/pull system in place at one point so that you did not have to get out of the car to lower the headlights.
Zach |
barefoot |
May 25 2017, 11:38 AM
Senior Member Group: Members Posts: 1,282 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
jmitro |
May 25 2017, 11:51 AM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
how much weight is saved by doing the GT headlight conversion?
csdilligaf |
May 25 2017, 01:46 PM
Thanks for the info guys. I wasn't sure if you had to push them down by hand. The kits seem pretty nice and well done. I know it only saves a little weight but its just one less electrical thing to go wrong and it has a cool factor since I love all things mechanical.
mb911 |
May 25 2017, 01:49 PM
914 Guru Group: Members Posts: 6,900 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
914dave |
May 25 2017, 02:06 PM
914 Addict Group: Members Posts: 706 Joined: 19-October 03 From: Willow Grove Pa. Member No.: 1,262 Region Association: North East States |
gms |
May 25 2017, 02:35 PM
Advanced Member Group: Members Posts: 2,695 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
although the weight savings may seem trivial it was one of many parts that collectively reduced the weight of the race cars. The added bonus of the headlight motor delete is that they lay outside of the wheel base at the very front of the car.
ConeDodger |
May 25 2017, 02:44 PM
McMark said about #10# So 13# is in the ballpark. Especially if they pared away the unneeded wiring.
pete000 |
May 25 2017, 04:51 PM
Senior Member Group: Members Posts: 1,885 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
Yup, on the list to do things...
jmitro |
May 26 2017, 05:55 AM
although the weight savings may seem trivial it was one of many parts that collectively reduced the weight of the race cars. The added bonus of the headlight motor delete is that they lay outside of the wheel base at the very front of the car. definitely; couple lbs here, couple lbs there. it all adds up for a full race car. |
VaccaRabite |
May 26 2017, 06:48 AM
I read somewhere that the old formula was the removing 10 pounds was like adding 1HP.
But I've also read that painting ones car yellow will make it go faster, and that stickers add 5HP. Still, removing 10 pounds should make a difference in your Power/Weight ratio. Those motors are heavy. Zach |
mb911 |
May 26 2017, 07:16 AM
Kits are kind of expensive but something I may consider when the time comes.
Marek |
May 26 2017, 08:24 AM
Newbie Group: Members Posts: 20 Joined: 27-April 15 From: Copenhagen , Denmark Member No.: 18,672 Region Association: None |
I Am just finishing a kit, as part of the Gt Repro parts we are working on
with all you need to do this conversion just waiting for the wires , should be here in 2 weeks Will post pics and a for sale add ASAP A kit will be 500 Euro incl shipping , and its spot on to original that was build on Magura bike parts Marek |
mb911 |
May 26 2017, 11:16 AM
Lo-Fi Version | Time is now: 15th June 2024 - 06:26 PM |
