Clutch replacement info needed, questions about flywheel and main seal.. |
914zim |
May 11 2005, 11:51 AM
Still pretty clueless... Group: Members Posts: 221 Joined: 29-July 03 From: New Berlin, WI Member No.: 962 |
Hey fellas:
I'm well into my clutch replacement project. Unfortunately, I don't get as much time to work on it as I'd like, but some time is better than nothing, I guess. I was searching through the archives regarding clutch cable replacement today and I read something that got me thinking... My car has only 76K miles on it - total stock. Clutch was slipping, which is why I'm replacing it. I did NOT get any machining done on the flywheel, because of the relatively low miles and it "looked" OK when I had it out (no scoring, etc.). I got the clutch kit from PP with the new pressure plate and disk. Is machining the flywheel an absolute MUST when doing this repair? What would NOT getting it machined do/cause? Also, I ordered the main seal with the kit as recommended, but didn't come across any mention of it in the procedure. How can I tell if I need to replace it? Where exactly is it located? I suppose I shoudn't have started putting it back together before I asked these questions. Dammit. Thanks for any help. Andy... |
914zim |
May 11 2005, 11:53 AM
Sorry guys, the seal I referred to above is the smaller one. I did replace the bigger one that goes on the flywheel.
736conver |
May 11 2005, 11:58 AM
Advanced Member Group: Members Posts: 2,117 Joined: 25-May 03 From: SE Wisconsin Member No.: 736 Region Association: None |
Andy,
I dont have a reply pertaining to your question, but nice to see you back up on the site. I thought maybe you sold your car. Brian |
914zim |
May 11 2005, 03:35 PM
914zim |
May 11 2005, 08:16 PM
Hey Brian:
Nope, still have the 914... trying to get through this clutch replacement project though. Hopefully, the guys can give me some help. Andy... |
Joseph Mills |
May 12 2005, 12:03 AM
on a Sonoma diet now... Group: Members Posts: 1,482 Joined: 29-December 02 From: Oklahoma City, OK Member No.: 39 |
Do you have the 3-piece kit (pressure plate, clutch disc & throw-out bearing), or the delux kit?
The delux kit has the following: New Pressure Plate New 911 Clutch Disc New Throw-out Bearing PLUS: New Pilot Bearing and Felt Ring 2 Throw-out Bearing Guide Clips New Throw-out Fork Bushing 2 CV Joint Gaskets 2 Muffler Gaskets New Flywheel O-Ring New Flywheel Bolts New Flywheel Metal Crush Gasket Clutch Disc Alignment Tool If you don't have the delux kit, I would suggest you purchase all those small parts (not very expensive), on that list and install them. The small engine seal is behind the flywheel. You also need a Haynes Manual - it will provide you with the torque specs you should be using. You could take your flywheel to a porsche shop, or speed shop in your area and see what their appraisal is. If not, you can go to my recent post on this same subject and get some info. One of the posts has a diagram of a flywheel, with the specs. It's very easy to measure them. Might help you determine the condition of your flywheel. Maybe some others will have more thoughts on the flywheel. Good luck! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
914zim |
May 12 2005, 12:10 PM
Thanks.
I have the "deluxe" kit from PP and am starting to reassemble everything. The friction plate was not worn (not down to the rivets) and the FW wasn't scored (only 76K miles). I just wondering of I can just reinstall the FW without having any machining done to it without any problems down the road (so to speak). Andy... |
Lo-Fi Version | Time is now: 2nd June 2024 - 10:25 AM |
