fan flange removal |
JFG |
May 29 2017, 11:22 AM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
I tried to remove the fan flange so that i can replace the seal behind it but it hasn't budged.
Is there a knack to removing this? Is it safe to fix the puller straigjt onto the flange or is it too brittle? |
iankarr |
May 29 2017, 11:56 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,481 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Are you referring to the fan hub? If so, after you take out the center bolt, you can take some super thick washers or thick metal stock and place between the hub and case under all three fan bolt holes. Make sure the metal overlaps the case by a good amount. Put the bolts back in (without the fan) and slowly tighten them equally against the washers/metal (kind of like a steering wheel puller) until the hub pops. And pop it will. Make sure you don't lose the woodruff key when it pops. Use some cloth as a catch all. If you use washers, make sure they're at least 3/16 thick so they don't bend or allow the bolt to pierce through and damage the case.
McMark |
May 29 2017, 12:04 PM
Getting them to pop off can be a PITA. But Ian's got the right technique. |
JFG |
May 29 2017, 12:27 PM
Thanks for the tip. I think i have some 5mm flat bar that will hopefully fit between the hub and case. Back on it tomorrow.
Dave_Darling |
May 29 2017, 12:32 PM
Make sure you have something under your work area to catch the Woodruff key when it jumps out of the keyway in a desperate bid for freedom. Or be ready to spend 10-40 minutes chasing all over the garage floor looking for it.
(Don't ask how I know.) --DD |
Lo-Fi Version | Time is now: 8th June 2024 - 01:26 AM |
