2.0 muffler vs 1.7 muffler, will the 1.7 fit??? |
pete-stevers |
May 11 2005, 09:20 PM
saved from fire! Group: Members Posts: 2,642 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
I have a blown out2.0/4 muffler and have a 1.7 muffler system willl the 1.7 fit??? IF not- does any body have a spare 2.0 that I can buy to get me through the next few months until the six is put in.....if it is rusty i can spray it flat black and no one will know.... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
dmenche914 |
May 11 2005, 10:48 PM
Senior Member Group: Members Posts: 1,212 Joined: 27-February 03 From: California Member No.: 366 |
The 2 liter muffler is designed to fit the 2 liter heat exchangers, which are different than the 1.7 heat exchangers. The 1.7 exchangers bend up at the ends near the muffler, the 2.0 heat exchangers have no bend, and go straight back. the effect of the bend is that the ends of the 2.0 heat exchangers are higher up, than the 1.7. The different muffler styles take this into account, so the inlet on the 2.0 liter muffler is higher than on the 1.7 motor. If you try to put the 1.7 muffler on the 2.0 heat exchangers, it would be too high up, and hit the trunk bottom.
The heat exchangers are interchangable, so you can put 1.7 exchangers, and 1.7 muffler on a 2.0 motor, and visa versa. hope this is clear enough good luck |
SLITS |
May 11 2005, 10:50 PM
No!
tat2dphreak |
May 12 2005, 07:53 AM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
dmenche914 gave you all the pertinent info...
one thing I'd add though: DON'T put 1.7 H/E's on UNLESS they are SSI... the 1.7/1.8 H/E has a smaller diameter than the stock 2.0.... UNLESS they are Stainless... all stainless H/E's have the same diameter(bigger than stock 2.0 even) |
Cap'n Krusty |
May 12 2005, 08:06 AM
Clear enough? Yes, but you've got it mostly wrong. The 1.7 HEs do indeed kick up, but the inlets on the muffler are also higher up, NOT lower. The 2 litre muffler has the inlets LOW on the muffler to match the straight HEs. The flanges are also substantially larger on the 2 litre muffler. The Cap'n |
914werke |
May 12 2005, 09:26 AM
"I got blisters on me fingers" Group: Members Posts: 10,120 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Pete I have a Monza 2.0 muffler that I yanked off the silver (blue) car yesterday if ya wanna come on down $40 and its yours. (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif)
pete-stevers |
May 12 2005, 10:32 AM
you bet.... i'll pm you for the details, thanks (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif)
steve |
Lo-Fi Version | Time is now: 2nd June 2024 - 03:40 PM |
