e-brake woes |
e-brake woes |
Schnell944 |
Jul 1 2003, 07:18 PM
Member Group: Members Posts: 121 Joined: 4-January 03 Member No.: 86 |
my e-brake doesnt seem to work. i pulled the cover that goes over the cables that go into the firewall to the brakes. they seem a little slack....is there any way to tighten them up, or should i just expect the worst: that the rear brakes are bad? also, I'm not driving the car really yet....whats an easy way to see if the rear brakes work correctly in my driveway? thanks!
Jeffs9146 |
Jul 1 2003, 07:23 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
Check the pads first then there is an adjuster nut on the outside of the caliper that will adjust the clearence between the rotor and the pad. There is also an adjustment near the handle.
Jeff |
garyh |
Jul 1 2003, 10:26 PM
Member Group: Members Posts: 170 Joined: 8-January 03 From: San Mateo, CA Member No.: 114 |
The adjustment is an allen-screw -inside- the caliper. The "nut" you see on the outside is the dust cover for the adjustment.
There is a hole through the trailing arm that allows you to get at it with the car assembled. There are adjustments for the cable slack, and the venting clearance. The Haynes manual describes both. If you just got the car, it very likely that both adjustments are wrong, but the calipers are probably OK. |
Jeffs9146 |
Jul 2 2003, 11:52 AM
visual!
Jeff Attached image(s) |
rhodyguy |
Jul 2 2003, 12:03 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
where the cables exit the firewall you can adj by loosening the lock nuts and turning the other nut. i was just reading about this in the lash book and it explains the whole proceedure very well. for those that don't have one i suggest you get one. their directions seem to be written beter to me. the haynes is the greasy one for the garage.
kevin |
Schnell944 |
Jul 2 2003, 04:28 PM
what book is this you speak of?
Aaron Cox |
Jul 2 2003, 04:42 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
the porsche factory manual....
how do i post an attachment? |
Aaron Cox |
Jul 2 2003, 04:46 PM
this: (i have the whole catalog on PDF)
Attached image(s) |
Schnell944 |
Jul 2 2003, 06:55 PM
duhhhh....you think I would have looked at the obvious things, like if the cables were actuall connected!....bother were disconnected and seem to be missing some sort of pin.....can I buy these seperately from somewhere? i'm thinking using a screw as a pin isnt the best idea....
Jeffs9146 |
Jul 2 2003, 07:12 PM
oooopps!! lol I hate it when that happens!!
Jeff |
tryan |
Jul 2 2003, 07:37 PM
Senior Member Group: Members Posts: 553 Joined: 22-January 03 From: smokey mountains gatlinburg tn Member No.: 184 |
you might want to take all the cables off and soak them in 10wt or hydrolic (sp) for a day or so. if they have not been used in a while they may be quite crusty.
Schnell944 |
Jul 2 2003, 08:14 PM
(IMG:style_emoticons/default/beer3.gif) good idea!
rhodyguy |
Jul 3 2003, 07:14 AM
this book.
kevin Attached image(s) |
mskala |
Jul 3 2003, 01:34 PM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
You should be able to get a pin and cotter that will fit roughly at any hardware store.
Lo-Fi Version | Time is now: 12th June 2024 - 01:50 AM |
