jrcui |
Vinny ![]() ![]() Group: Members Posts: 80 Joined: 5-November 04 From: beaverton, or Member No.: 3,062 ![]() |
(IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) Got my first teener this past week (75 2.0) but gotta take care of a few issues to get it registered, i.e., pass the Oregon DEQ inspection. The car is idling high/low so I'm assuming its a vacuum leak. I'm going to change out the vacuum hoses using the Auto Atlanta kit. Any other suggestions on potential leak spots?
Also, noticed my air pump isn't working... the pulley/belt isn't moving? Anyone got suggestions? I'm a complete mechanical novice but luckily have mechanic friend helping out. Get anxious and want to hit the road!!! Vince |
skline |
Born to Drive ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California ![]() |
I would use starting fluid or something like that and spray little bursts at the lines, if you have a leak, it will rev up a little. Do not spray it on or around the heat exchangers or exhaust manifolds
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,681 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) brakecleaner or carbcleaner will work great. spray on the area in question and listen for the idle to change (should go down if you have a leak) ... keep a fire extinguisher nearby ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
Joe Bob |
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None ![]() |
Carb cleaner works too....added benefit cleans up the engine bay.
On your air pump...unless you need it to pass smog...leave the belt off. Call the inspection station and ask....pretty sure the pump was CA thing in 75.... |
Lo-Fi Version | Time is now: 10th June 2024 - 09:27 PM |
