Frt. Oil Cooler & A/C Condensor Box???, Can they co-exist (for the /6) |
DougC |
May 12 2005, 02:00 PM
Senior Member Group: Members Posts: 949 Joined: 6-July 04 From: Dallas, TX Member No.: 2,307 |
I really want to use the GT oil cooler shroud but will be installing the big square A/C condensor box in the floor of the front trunk, I haven't looked closely but I really doubt they'd both fit. So what are my options?
Doug c |
TravisNeff |
May 12 2005, 02:19 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
Take the box & fan off the A/C, you'll get it pretty low in the floorpan that way, you'll probably use a fan for the Oil cooler up front - so it would seem like it would work out OK. However, the Hole for the A/C goes a bit further back than the GT shroud does (I think), but you can reposition and fill that.
DougC |
May 12 2005, 02:35 PM
Seems like the A/C would still need it's seperate fan to be efficient at stops though, and I don't want heat from the cooler cancelling the cooling effects of the a/c condensor... Maybe I could fabricate a custom shroud incorporating the big stock box.
Doug C |
TravisNeff |
May 12 2005, 02:37 PM
You could also use a slim depth fan on the A/C stuff, you may need to mod the shroud for a little more lift in the rear. Definately doable from my perspective
DougC |
May 12 2005, 02:59 PM
Gotcha, thanks..I'll investigate this further. I haven't figured out which cooler I'll be using yet or bought the shroud, but I may just make my own.
Doug C |
TravisNeff |
May 12 2005, 03:20 PM
I have the square box unit for the trunk, not the round hat style one. It is sitting under my workbench - I can take it apart and get some measurements/pics if you like.
DougC |
May 12 2005, 03:30 PM
Travis, thanks but I have the same thing sitting in my garage. Unless I can't figure out how to get it all seperated. I actually have a complete HVAC unit from an '88 M3 also sitting in my garage and I may be able to use some of it for my a/c project.
Doug C |
Lo-Fi Version | Time is now: 12th June 2024 - 08:07 AM |
