Installing the Bumper Top, per Darren C |
76-914 |
Jun 11 2017, 09:53 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I installed my 914 front bumper top two months ago but just now got around to "taming" the ends. Darren C covered this in his build thread( http://www.914world.com/bbs2/index.php?sho...47250&st=60 day 164)but did not provide much detail. Anyway, here are a few pic's of mine being tamed. In this first pic you can see how the ends look once the bumper top is secured to the bumper. And yes, I know my bumper is dirty. (IMG:style_emoticons/default/dry.gif)
Notice how I center punch a wee bit inboard of center. This was to give myself a bit more room to turn the screwdriver from inside the bumper. If the hole is too close to the bumper (the place where bumper & rubber meet) you will play Hell turning the screw with a screw driver. This is where I varied from Darren's method. Rather than remove the rubber top I simply maneuvered it to one side whilst drilling. Once the bumper is drilled, pull and hold the rubber end in place then using the hole in the bumper as a guide, insert a "push pin" into the rubber. This will mark the spot you'll need to drill the rubber. Drill out the rubber paying close attention to the angle of the hole. You don't want to pop out the side of the bumper top. You can see why I drilled a bit off center as you need all the room you can get to tighten the screw. With the screw tightened the edge pulls in quite nicely. Attached image(s) |
Steve |
Jun 11 2017, 01:49 PM
914 Guru Group: Members Posts: 5,606 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Nice job!!! Looks great!! I have the same issue with my 914 rubber bumper tops. Would the bumper top spacers help? Why don't the factory ones have this issue?
I hate to jury rig my car or drills hole in it, just because some after market part doesn't fit right. |
rhodyguy |
Jun 12 2017, 08:46 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
You need to treat the rust on the back of your bumper(s) kent.
mepstein |
Jun 12 2017, 09:00 AM
914-6 GT in waiting Group: Members Posts: 19,305 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
If you are going to go that direction, I would bond a small stud in the rubber top and then you could tighten down into the bumper with a washer and nut. Sort of a small version of how it fits on top of the bumper.
76-914 |
Jun 12 2017, 09:08 AM
Nice job!!! Looks great!! I have the same issue with my 914 rubber bumper tops. Would the bumper top spacers help? Why don't the factory ones have this issue? I hate to jury rig my car or drills hole in it, just because some after market part doesn't fit right. I hear you Steve. You'd need an OEM one for your 914. For mine and most other's the 914 top is fantastic and I'm glad to have it. I'm sure 914rubber will address the shrinkage issue in the future. Besides, I could never complain given the group buy price. (IMG:style_emoticons/default/beerchug.gif) |
76-914 |
Jun 12 2017, 09:09 AM
You need to treat the rust on the back of your bumper(s) kent. Yes, your correct Kev. It isn't as bad as it appears. You know how the flash amplifies the rust condition. How's everything? (IMG:style_emoticons/default/beerchug.gif) |
76-914 |
Jun 12 2017, 09:10 AM
If you are going to go that direction, I would bond a small stud in the rubber top and then you could tighten down into the bumper with a washer and nut. Sort of a small version of how it fits on top of the bumper. That sounds like a lot of work! (IMG:style_emoticons/default/sad.gif) |
Lo-Fi Version | Time is now: 31st May 2024 - 06:22 PM |
