| Garland |
Jun 16 2017, 01:13 PM
Restoration Fanatic ![]() ![]() ![]() Group: Members Posts: 1,430 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest
I have reduced the size by cutting it down, and would like to finish it off with the same look where I cut it.
A thick varnish may work? |
| Tom_T |
Jun 16 2017, 01:57 PM
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California
I have reduced the size by cutting it down, and would like to finish it off with the same look where I cut it. A thick varnish may work? You can't use anything solvent based, or it will melt the foam. Maybe a brush-on water-based urethane varnish from the DIY might work, but test a small area 1st. (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
| 6freak |
Jun 16 2017, 02:20 PM
MR.C ![]() ![]() ![]() ![]() Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest |
try a heat gun with the piece you removed .....OUTSIDE LOL
| Rand |
Jun 16 2017, 02:47 PM
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,414 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Why bother? It's covered with carpet, right? (Not trying to be sarcastic, just curious.)
| 6freak |
Jun 16 2017, 02:52 PM
varnish may stink for a looooong time....
| 914_teener |
Jun 16 2017, 03:03 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,270 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
| porschetub |
Jun 16 2017, 03:19 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,081 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Its not polystyrene so won't eat away with solvent paint,appears to be the same as spray foam but done in a mold.
You could always test with the cut offs to see if you have a reaction but you should be ok. |
| Garland |
Jun 16 2017, 04:12 PM
Its not polystyrene so won't eat away with solvent paint,appears to be the same as spray foam but done in a mold. You could always test with the cut offs to see if you have a reaction but you should be ok. Thanks for all the fast responce, I did try solvent on a cut off, held up fine. Now on to paint, and the color. Here a pic of what Im doing. Full story will be shown in my Michigan Build link, soon. |
Lo-Fi Version | Time is now: 16th April 2026 - 05:26 AM |
