Paint Repair |
Paint Repair |
bd1308 |
May 13 2005, 12:24 PM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
okay, i have a spot down to metal the size of a quarter on my rear quarterpanel(the car's not mine) how can i fix it...i'll take a pic tonite.
1bad914 |
May 13 2005, 12:52 PM
Senior Member Group: Members Posts: 618 Joined: 6-May 04 From: Battle Creek, MI Member No.: 2,028 |
The correct way would be to paint the quarter, the other way is to roll 2-3 coats of primer over the repair, yes they make primer rollers, make sure you feather the edges. Then wet sand the primer and check for flatness, if flat you tape a square/circle what ever design you want around the repair and roll the tape back, as in expose the sticky side to the repair. Spray base coat to cover repair, let dry, remove tape and check for hard edges, wet sand/blend any hard edges, then roll the tape again in a larger circle than the base coat, spray your clear coat 2-3 coats, let dry over night and remove tape, wet sand to blend clear and rub out to shine. Easy stuff! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
All of this is based on your paint being a good match, metllics are harder to blend , but can be done. What is the location on the quarter and what is the color? Also I'm leaving out some obvious prep steps, covering the rest of the car and so on... |
bd1308 |
May 13 2005, 12:55 PM
okay my brother backed his jeep into my car and popped off a part of the bondo(maybe) on the QP....well its prolly not bondo but its kinda deep and i need filler i guess to *TRY* to fix this...the body shop will fix it but for a fee.......
need to fill hole with bondo or filler sand wet sand primer paint wet sand paint wet sant CC something like this? |
1bad914 |
May 13 2005, 12:59 PM
You can add filler to the steps I mentioned, just put it on the bare metal, roughen the bare metal up for better adhesion, sand flat and use the steps I mentioned, I would put multiple thin layers on to avoid future problems. It can be done, it just takes time. Then again I may be assuming that you have the gun and equipment.
roughen fill sand sand some more (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) primer sand paint base coat wet sand edges if needed cc wet sand rub polish |
SGB |
May 13 2005, 01:33 PM
just visiting Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
Really, you should mask also for the wet sanding, since you will end up removing some original paint with the sanding of the raised edges of the new paint. Go ahead and protect that surface to reduce the area you need to sand/ polish/ blend. I have never been successful with a truely invisible line, but have gotten close, but I've also accidently dulled the paint WAY OUT from the original gore zone.
Lo-Fi Version | Time is now: 11th June 2024 - 06:10 PM |
