> Front piston retaining plate
Pachla
post Jun 30 2017, 07:39 PM
What does the piston retaining plate do on the front brakes? Mine are all bent up.
Replies(1 - 2)
Bob L.
post Jun 30 2017, 08:39 PM
It prevents the piston from rotating in the caliper bore.
Why? (IMG:style_emoticons/default/confused24.gif)
Firstcar
post Jun 30 2017, 09:24 PM
Obsessive amateur mechanic
QUOTE(Bob L. @ Jun 30 2017, 10:39 PM) *
Because the face of the piston that contacts the pad has a slight angle to it and is supposed to be installed in a particular orientation in the caliper. I think the designated angle helps the pad bite the rotor properly, prevents pad vibration/squeal and helps the pad wear more evenly. The plate prevents the piston from rotating in its bore ensuring it retains the proper angle.
- Lo-Fi Version Time is now: 11th July 2025 - 01:19 PM
