Odyssey, baby, you lika da juice, no? |
mskala |
May 14 2005, 11:38 AM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
Odyssey battery mounted. Thanks to MXMARK for
the hold-down. 15 lbs, with enough power for the weather most of us would be driving in. Not mounted to the tray, I already had a bottom plate that fit over the tray and is held down by the bolt and notch on the other side. Just another way of making the car more left-heavy. Attached image(s) |
Qarl |
May 14 2005, 02:06 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Yes.... I like the juice... the juice... it is GOOD!
J P Stein |
May 14 2005, 07:58 PM
38 to 14 lbs. Spark is gud, but adding lightness is better
Attached thumbnail(s) |
mskala |
May 14 2005, 08:10 PM
The thing that gets me is that the tech guys used to come over and
practically throw themselves on my normal-sized battery. Hmm, 200lbs on a 38lb item; I guess they think my car is turning like an F16. The channel on the outboard side is bent at this point. |
MXMARK |
May 15 2005, 12:24 AM
Member Group: Members Posts: 205 Joined: 15-February 04 From: Riverside, Ca. the new (951) Member No.: 1,656 |
Mark, it looks good. Thanks Mark here is mine in black
Attached image(s) |
ottox914 |
May 15 2005, 06:29 AM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
J.P.- that is one smooth install- which model battery is that, and where did you source it? I want to duplicate that in my car!
bd1308 |
May 15 2005, 07:12 AM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
that name creeps me out.....otto
d914 |
May 15 2005, 07:53 AM
Advanced Member Group: Members Posts: 2,331 Joined: 12-July 03 From: Atlanta, ga Member No.: 904 Region Association: South East States |
there is an acura site that sells them for $109 for the battery and 70 for the hold down. Thats about the best I've seen..
Attached image(s) |
Qarl |
May 15 2005, 08:14 AM
MUCH cheaper here!
Here is the 680 Model http://www.gotbatteries.com/Productpage.as...uctNum=37L105S5 Here are all the rest. http://www.gotbatteries.com/products/slaba...ies/Odyssey.asp Best prices that I could find... |
J P Stein |
May 15 2005, 08:41 AM
Karl nailed it. It's the first instance that I've found something more expensive at Summit Racing. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
The aluminum strap tightens against the battery as the hold down screw tightens. The upset in the trunk floor keeps it from moving laterally.....the spot is like it was made for it (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) I loaded oil yesterday and it spins the motor over nicely. Today we add gas & lightem' up. |
d914 |
May 15 2005, 10:01 AM
Damn!!!! next one I get is from there. even with the add on posts ( were included with mine) still cheaper!!!! COOOL...
Marv's3.6six |
May 16 2005, 07:59 AM
Actual member 7" Group: Members Posts: 695 Joined: 22-November 04 From: Huntington Beach, Ca. Member No.: 3,165 Region Association: Southern California |
Anybody used one of these for a significant amount of time?
Will it spin a 3.6? (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) |
d914 |
May 16 2005, 08:39 AM
I've used it to spin my race motor that was outside in 40 degrees and colder over night. Got it going with no outside help. I carry one of those emergency chargers to help with the starts...haven't used it yet...I've been pretty impressed to date. Been in car 6 months.....long term storage with occasional re starts...no problem.. no outside drain, cut off switch.
MXMARK |
May 16 2005, 09:39 AM
Marv, I have been using one in my 911 for about 9 months now with no problem. Let me know I have these batteries new from my work. And I should be able to get another box. I have been told that I should be using a 925 instead of the 680 in my 911 because of all of the accs. A/C, radio, cruise, windows, etc. but the 680 has worked well. My 911 turns over quicker then my big 2.5L 4 cylinder with the 680. The 680 works well in the 914 but my stereo has a drain I need a cut-off swicth. Good luck with the 3.6L Thank you Mark |
Lo-Fi Version | Time is now: 8th June 2024 - 09:12 AM |
