| second wind |
Jul 3 2017, 01:03 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 862 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California
Hey guys, my '73 2.0 runs perfect and has d-jet. Just driving up the street notice it sounded weird and wouldn't rev past 4,000 and sounded labored doing so. Still idles but feels like it is on two cylinders or something. Pulled plug wires off each cylinder while running and each cylinder did make a change so all four are firing. I do have a pertronix. I wonder is there a fuel pump relay or other relay that could be messing up? Thank you.
gg |
| JeffBowlsby |
Jul 3 2017, 01:45 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,246 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
Oiled your dizzy counterweights lately? 1 drop of 30 wt in the center of the dizzy shaft annually is what the manual recommends. When the weights stick, you get slow acceleration.
| second wind |
Jul 3 2017, 02:14 PM
Oiled your dizzy counterweights lately? 1 drop of 30 wt in the center of the dizzy shaft annually is what the manual recommends. When the weights stick, you get slow acceleration. Will give it a go.....funny how time flies....probably has been a year.....thanks, gg |
| mgphoto |
Jul 3 2017, 03:19 PM
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,463 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Greg,
Check to see if the dizzy is loose, if not, pull the cap and look at the plate holding the Pertronix, can you move the lug where the vacuum can attaches, with a screwdriver? Both directions? Mike |
| second wind |
Jul 3 2017, 04:35 PM
Lo-Fi Version | Time is now: 1st May 2026 - 02:24 PM |
