| daytona |
Jul 8 2017, 06:26 PM
daytona ![]() ![]() Group: Members Posts: 488 Joined: 13-April 14 From: Ormond Beach, Florida Member No.: 17,249 Region Association: South East States |
Hi, I have a backpad that needs repair (some water damage, tears, cracks, etc...).
Anybody have any ideas on repairs to the fiber board? I have tried to search the forum but could not find threads on repairing the backpad. Thanks, Bill. |
| ConeDodger |
Jul 8 2017, 07:36 PM
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,539 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California
My best idea? Don't...
Check 914Rubbers fiberglass backpad and backpad vinyl. Looks like this when it's in: Attached image(s)
| Tom_T |
Jul 8 2017, 08:32 PM
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California
My best idea? Don't... Check 914Rubbers fiberglass backpad and backpad vinyl. Looks like this when it's in: (IMG:style_emoticons/default/agree.gif) ... with Rob! Even if you keep your own fabric & foam materials, & just put it on the 914Rubber fiberglass backpad panels, it will be better than the water damaged OE fiberboard. If you need to be super low cost, then go to the local Home Depot or other DIY & get some 2 part resin or epoxy to try to repair the water damaged areas. You may need to cut away substantial amounts of the funky fiber layers that are water damaged, so you then have to lay in fresh fiberglass cloth &/or paperboard to build it back up. It will still be funky though. I did this on the 2 small corners of a door card on one of my cars, but I don't recommend it for large areas. Good Luck! (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
| raynekat |
Jul 8 2017, 08:38 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,171 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest
The biggest problem you'll find with the 914 Rubber back pad is that's it's made of fiberglass so staples won't go through it. MPITA. I repaired my fiberboard original the best I could using a fiberglass repair kit but the repairs were not where the staples go. I'll put a couple of pics here in the coming days.
Not saying anything bad about the 914 Rubber part....it's just not easy or straight forward to work with. |
| ConeDodger |
Jul 8 2017, 08:47 PM
The biggest problem you'll find with the 914 Rubber back pad is that's it's made of fiberglass so staples won't go through it. MPITA. I repaired my fiberboard original the best I could using a fiberglass repair kit but the repairs were not where the staples go. I'll put a couple of pics here in the coming days. Not saying anything bad about the 914 Rubber part....it's just not easy or straight forward to work with. I agree but... I worked with an upholstery shop (and coincidently, now, so is 914Rubber) that made that same suggestion. On mine we attached a tack strip and we sent Mark a sample of it. Look for the next-gen backpad fiberglass to have that improvement. |
| porschetub |
Jul 8 2017, 09:43 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,157 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
My best idea? Don't... Check 914Rubbers fiberglass backpad and backpad vinyl. Looks like this when it's in: (IMG:style_emoticons/default/agree.gif) ... with Rob! Even if you keep your own fabric & foam materials, & just put it on the 914Rubber fiberglass backpad panels, it will be better than the water damaged OE fiberboard. If you need to be super low cost, then go to the local Home Depot or other DIY & get some 2 part resin or epoxy to try to repair the water damaged areas. You may need to cut away substantial amounts of the funky fiber layers that are water damaged, so you then have to lay in fresh fiberglass cloth &/or paperboard to build it back up. It will still be funky though. I did this on the 2 small corners of a door card on one of my cars, but I don't recommend it for large areas. Good Luck! (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) Tom /////// No need to use epoxy,polyester is fine mine came out a treat. From my pic you see I gave it a resin rich coat to hold the cardboard together,let that dry and sand it back and used surfboard cloth to beef it up,really works but time spent of course. The main reason for the resin coat is to hold the broken area and provide a way of sanding back the staple ends that have popped through,you need to cut out some broken bits to get the pad back into shape. Best to use some bondo (bog we call it ) to get a good surface to glass over,be aware it will smell for a few days then it comes right. |
| EdwardBlume |
Jul 9 2017, 02:06 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,340 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California
I used bondo and gorilla glue with a 914rubber kit. Even cut some from a donor panel. You'll never see it. (IMG:style_emoticons/default/laugh.gif)
| gereed75 |
Jul 9 2017, 04:15 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,446 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States
I have not tackled this job yet but I was thinking that one of the wood rot epoxy products would be the ticket. These products are made to soak into the fibers.
Has Anyone tried that?? |
| barefoot |
Jul 9 2017, 06:26 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,538 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States
| Keith914 |
Jul 9 2017, 08:13 AM
Member ![]() ![]() Group: Members Posts: 248 Joined: 29-April 16 From: Laguna Beach, California 92651 Member No.: 19,948 Region Association: Southern California |
I used the 914 Rubber fibre glass boards and glued with 3M upholstery glue and screws with clips in critical areas. I ground off the sharp screw ends and covered with strips of duct tape. I learned the hard way to protect myself from the drill cuttings/dust when working fibre glass!
| daytona |
Jul 9 2017, 02:16 PM
Hi guys,
Thanks for all the suggestions and information. I need to do this on the cheap if I can so I will try the resin and fiberglass first. Thanks, Bill. |
| saigon71 |
Jul 9 2017, 02:56 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,029 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region
I used the fiberglass cloth & resin method on my lower corners. It worked very well. See post #367.
http://www.914world.com/bbs2/index.php?sho...3957&st=360 |
| daytona |
Jul 9 2017, 06:08 PM
Thanks for the info saigon71.
Bill. |
Lo-Fi Version | Time is now: 14th August 2026 - 08:51 AM |
