Adding fuses to the four 12 volt wires direct to the battery, What current rating should I use? |
Kansas 914 |
Jul 10 2017, 10:48 AM
Advanced Member Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains |
I am adding a 6 circuit fuse block to the wiring harness in the engine compartment and I wonder what amp fuse I should use for the 4 red wires that are connected directly to the battery positive terminal. I am also adding one circuit for the audio amp and a spare circuit I added to the passenger compartment (Seat heaters, etc.).
I think two of these go to the regulator plate and two go to the front fuse panel. I have to think 25A or greater would be fine as I am just trying to eliminate a problem if there should be a dead short midstream, plus it gives ma a nice takeoff point for trouble shooting. Thoughts? Thanks in advance! |
mzalanka |
Jul 10 2017, 12:34 PM
Member Group: Members Posts: 116 Joined: 11-July 11 From: Portland, OR Member No.: 13,300 Region Association: None |
This old thread about a member-built kit might be of use:
http://www.914world.com/bbs2/index.php?sho...=141317&hl= |
Kansas 914 |
Jul 10 2017, 01:21 PM
This old thread about a member-built kit might be of use: http://www.914world.com/bbs2/index.php?sho...=141317&hl= Very helpful - thanks! |
Lo-Fi Version | Time is now: 9th June 2024 - 06:13 AM |
