Krieger |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,808 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None ![]() ![]() |
There are two here. One assembled. One pulled apart. Each strut can was loaded with oil and so were these tubes.
Attached thumbnail(s) ![]() |
Racer |
Senior Member ![]() ![]() ![]() Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region ![]() |
Maybe the pnuematic shocks from a 911E ?
http://www.caranddriver.com/comparisons/91...1e-coupe-page-4 QUOTE The hydropneumatic front suspension, made by BOGE, fits entirely within the MacPherson strut and is completely self-contained, requiring no external pumps or pressure tanks. And, since the entire suspension function is performed by a piston acting on a high pressure gas chamber, no springs or anti-sway bars are used. The car's height is controlled by the position of the piston in its cylinder. Regardless of the load, the piston can be moved to a predetermined point by adjusting the pressure in the chamber. For instance, when a load is placed in the trunk, the front of the car goes down. After you start to drive, an internal pump—activated by suspension motion—pumps gas from a reservoir to the piston chamber and returns the front of the car to its proper height. Obviously the bumpier the road, the sooner the suspension reaches the proper height—but only on a glassy smooth surface should it take more than a quarter of a mile. |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,191 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
You got me, never seen any shocks like that.
arne |
Serial Rescuer of old vehicles... ![]() ![]() ![]() Group: Members Posts: 779 Joined: 31-January 17 From: Eugene, Oregon Member No.: 20,799 Region Association: None ![]() |
Very standard construction of early, pre-cartridge struts in many cars. When replacing, you toss it all and slide an insert in. I'm going to guess those are from a VERY early 911.
Krieger |
Maybe the pnuematic shocks from a 911E ? http://www.caranddriver.com/comparisons/91...1e-coupe-page-4 QUOTE The hydropneumatic front suspension, made by BOGE, fits entirely within the MacPherson strut and is completely self-contained, requiring no external pumps or pressure tanks. And, since the entire suspension function is performed by a piston acting on a high pressure gas chamber, no springs or anti-sway bars are used. The car's height is controlled by the position of the piston in its cylinder. Regardless of the load, the piston can be moved to a predetermined point by adjusting the pressure in the chamber. For instance, when a load is placed in the trunk, the front of the car goes down. After you start to drive, an internal pump—activated by suspension motion—pumps gas from a reservoir to the piston chamber and returns the front of the car to its proper height. Obviously the bumpier the road, the sooner the suspension reaches the proper height—but only on a glassy smooth surface should it take more than a quarter of a mile. Maybe! |
arne |
No, those are normal, non-gas strut parts. The hydropneumatic struts were far more complex, having a gas chamber as well.
(IMG:http://www.914world.com/bbs2/uploads_offsite/forums.pelicanparts.com-20799-1499743644.1.jpg) |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,882 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
When working on VW golfs years ago only found this once,undid the top nut and oil pissed out when I pulled the unit upwards,if I remember right you can't fit inserts in because internal diameter is wrong....sounds like the same issue.these were Boge struts.
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,777 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
Very standard construction of early, pre-cartridge struts in many cars. When replacing, you toss it all and slide an insert in. I'm going to guess those are from a VERY early 911. Bingo! Standard operating procedure. Done it many times....messy business. Most were done long ago. |
Krieger |
Thanks guys! I wonder if they are worth anything. I am not going to use them. Maybe some CCW?
arne |
There is a good chance that they will accept inserts that fit Boge struts, as that is what they really are, even if they didn't come with cartridge inserts originally.
Krieger |
Arne I meant selling these inserts, not the struts. There are 2 seals for each, so they are rebuildable. Not much if any wear.
BillC |
Senior Member ![]() ![]() ![]() Group: Members Posts: 675 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region ![]() ![]() |
Arne I meant selling these inserts, not the struts. There are 2 seals for each, so they are rebuildable. Not much if any wear. I doubt the inserts are worth any more than their scrap weight. It would take a truly rabid CW to care that a part no one can possibly see without significant disassembly isn't the same as original, even if just for bragging rights. Plus, modern strut cartridges are far better than the original equipment parts. |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,831 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
My guess is hyrdro-pneumatic.
I always thought the hyrdo-pneumatic were unique and required complete replacement of the strut assembly, but I've never had my hands on them. Make sure you can use those with the front A arms. IIRC they don't all have compatible ball joints. |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,964 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Lo-Fi Version | Time is now: 11th July 2025 - 01:11 PM |
