911 Front suspension is goofed help!, threads stripped on strut cartridge retainer |
tazz9924 |
Jul 16 2017, 05:03 PM
Senior Member Group: Members Posts: 703 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
Ok so, i had a click from the front end of my car, i expected it to be the balljoints because their trash. come to find out the thing u screw in to retain the shock came off ( i did tighten the shift out of it before i installed it) and my newer koni shock has a hole rubbed in it and leaked all of its fluid. meanwhile the real killer is i cant rescrew the retainer back in because the threads on the tube thing are rubbed flat. My question is do i try to get the biggest tap ive ever seen or do i have to buy a whole new knuckle:( ?
The real killer is im moving to sacramento in two weeks and im driving the 914 down there! help! pm me if u got a drive side 911s koni strut/ knuckle thing ur willing to sell |
rgalla9146 |
Jul 16 2017, 05:18 PM
Advanced Member Group: Members Posts: 4,570 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Is it actually a 911 strut ? How far apart are the caliper bolts ?
You must know this to get the matching strut. Get the retaining collar too. If it's a 4 cyl. I think any standard strut will do. Don't waste time trying to repair your parts. |
tazz9924 |
Jul 16 2017, 05:33 PM
Is it actually a 911 strut ? How far apart are the caliper bolts ? You must know this to get the matching strut. Get the retaining collar too. If it's a 4 cyl. I think any standard strut will do. Don't waste time trying to repair your parts. its a 1972 911 s koni strut it has 5 lugs and 3.5" caliper spacing i have the boxster caliper adapters installed |
Cracker |
Jul 16 2017, 05:34 PM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
...one of our member hoarders' in the Midwest should be able to help! (IMG:style_emoticons/default/biggrin.gif)
T |
914Sixer |
Jul 16 2017, 06:28 PM
914 Guru Group: Members Posts: 8,912 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Early 911 Koni Reds with 3.5 spacing are rare items. Which ball joint does it take early or late?
tazz9924 |
Jul 16 2017, 06:37 PM
mepstein |
Jul 16 2017, 07:01 PM
914-6 GT in waiting Group: Members Posts: 19,325 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Early 911 Koni Reds with 3.5 spacing are rare items. Which ball joint does it take early or late? Early uses a pinch bolt and has a spit collar to hold the ball joint. Late uses a cotter pin style wedge bolt and is not split. |
tazz9924 |
Jul 16 2017, 07:04 PM
Early 911 Koni Reds with 3.5 spacing are rare items. Which ball joint does it take early or late? Early uses a pinch bolt and has a spit collar to hold the ball joint. Late uses a cotter pin style wedge bolt and is not split. it isn't split its solid |
rgalla9146 |
Jul 16 2017, 07:08 PM
Early 911 Koni Reds with 3.5 spacing are rare items. Which ball joint does it take early or late? One version is split at the bottom with a through bolt that grips the ball joint. The other version uses a wedge shaped threaded shaft with a nut to secure the ball joint. Koni S struts are precious. You're in for a hard search. |
mepstein |
Jul 16 2017, 07:15 PM
Early 911 Koni Reds with 3.5 spacing are rare items. Which ball joint does it take early or late? Early uses a pinch bolt and has a spit collar to hold the ball joint. Late uses a cotter pin style wedge bolt and is not split. it isn't split its solid Late is considered to be better. I would place a wtb on pelican. That's probably the largest pool off 911 owners. I did see someone selling just one Kony a little while ago. I don't remember what side. Here you go - http://forums.pelicanparts.com/porsche-911...ront-strut.html I think it's a driver side. |
rgalla9146 |
Jul 16 2017, 07:20 PM
Hold on a minute here.....
Please post a picture of the retainer that goes into that strut. Original Konis are not insert struts. They are serviceable units. Are there Koni markings on the strut ? I can attach a pic if necessary. |
Cracker |
Jul 16 2017, 07:32 PM
...or does it say BOGE??? Scratch that - my retaining nut threads are on the outside. Darn.
Tony PS: Sorry that happened to you! I hope the move goes well despite these hassles!!! (IMG:style_emoticons/default/beerchug.gif) |
tazz9924 |
Jul 16 2017, 07:35 PM
mepstein |
tazz9924 |
Jul 16 2017, 07:37 PM
rgalla9146 |
Jul 16 2017, 07:57 PM
...or does it say BOGE??? Tony PS: Sorry that happened - that sucks! From what i remember it say koni heavy steering or something like that The stamped 'heavy turn' has an arrow that indicates the direction to turn the shaft to set the strut to a heavier 'feel' The other direction would be a 'softer' setting. I'm pretty sure your strut is a Koni brand replacement. It will accept Boge, Bilstein or Koni inserts. You did say that your insert was loose ...right ? Konis as original optional equipment on a 911 would have the Porsche symbol and a Porsche part number stamped in. 901 341 079 10 Attached image(s) |
tazz9924 |
Jul 16 2017, 08:37 PM
...or does it say BOGE??? Tony PS: Sorry that happened - that sucks! From what i remember it say koni heavy steering or something like that The stamped 'heavy turn' has an arrow that indicates the direction to turn the shaft to set the strut to a heavier 'feel' The other direction would be a 'softer' setting. I'm pretty sure your strut is a Koni brand replacement. It will accept Boge, Bilstein or Koni inserts. You did say that your insert was loose ...right ? Konis as original optional equipment on a 911 would have the Porsche symbol and a Porsche part number stamped in. 901 341 079 10 Insert fit perfect, the piece that keeps the strut in place got loose and funked it all up |
Cracker |
Jul 16 2017, 08:46 PM
This may not be an option or good idea for you but...I have a GREAT machine shop that can fix most anything. Do you have access to one in your area? A good shop could make a new retaining nut modified to accommodate the repair. The strut tube could be cut lower (shortened) if necessary if the threads couldn't be straightened near the top. Again, maybe not a real solution but it got me thinking.
T |
tazz9924 |
Jul 16 2017, 09:00 PM
This may not be an option or good idea for you but...I have a GREAT machine shop that can fix most anything. Do you have access to one in your area? A good shop could make a new retaining nut modified to accommodate the repair. The strut tube could be cut lower (shortened) if necessary if the threads couldn't be straightened near the top. Again, maybe not a real solution but it got me thinking. T i was thinking about it... shortening the tube isn't really a great idea but rethreading it certainly is |
tazz9924 |
Jul 16 2017, 09:21 PM
suspension is part number 911 341 079 10
says made by koni and has their little triangle emblem it also says heavy turn and presumably heavy turn in german no other markings that i can see |
Lo-Fi Version | Time is now: 17th June 2024 - 05:44 AM |
