> Brembo GTP Lightweight, N E 1 done this upgrade
Marv's3.6six
post May 16 2005, 07:27 AM
Actual member 7"
I'm thinking about these for my GT conversion, the GTP Lightweight kit, anyone running them on a 914 or on a 911?
Replies(1 - 19)
xitspd
post May 16 2005, 07:38 AM
Technology and Tradition 3.6 and 914-6
Marv,
I am running Big Reds (993 Twin Turbo Brakes) on all four corners. The car has more braking capacity than needed, but I am happy with the over the top results. I will have the car back Hemet in about two weeks. You are welcome to come by and see it at that time. If you are going to OC before then, you stop by the shop in Orange and see it there.
Dan
Marv's3.6six
post May 16 2005, 07:46 AM
Actual member 7"
Dan, I need the Lightweight due to the fact I am staying with 16" wheels, AND from what Bill Verburg (911 brake expert) says the standard GTP's are WAY to front biased with the 44/40 pistons, I believe the lightweights are 40/36 pistons.
Just curious if N E 1 is runnin them?
slivel
post May 16 2005, 08:15 AM
Old car....... older driver
No, I'm not using those but I recently converted to Boxster monoblocks. They are lighter than the previous Carrera calipers (steel) and have about twice the pad area - also four piston. They work well with my SC rears and provide all the stopping power that I need in my GT-3S class car. Car weighs 2050 lbs and has a 3.4 L.
Aaron Cox
post May 16 2005, 09:40 AM
Professional Tinkerer
marv,
cant wait to see your ride dude.
what color did ya end up choosin?
have you looked into boxster calipers?
xitspd
post May 16 2005, 11:26 AM
Marv,
Excuse the hijack, but had a great mountain bike ride from Nature Park in Pine Cove to Bee Canyon yesterday. Seven guys, seven crashes. Wicked Awesome single track from the pines to the wild flower meadows below....
Marv's3.6six
post May 16 2005, 11:50 AM
Actual member 7"
Yeah me too, AND had a big getoff myself, 20+ mph, no damage except rasberry's and a bruised ego. A case of stupidity, going way to fast at a place I have only ridden once.
The good part though was I was riding with 3 30 somethings and I was able to walk away from them on the climbs.... on my single speed........and them on their geared bikes. There is no substitute for saddle time.
nocones
post May 16 2005, 12:05 PM
Sportscar lunatic
Steve,
What was needed to install the Boxter calipers? Excuse my ignorance, but I have yet to work out all the little differences and what will/will not fit and how much modification/machining is necessary to do so. (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif)
Thanks!
kermit
post May 16 2005, 01:56 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif)
I'm ignorant too! How do you get Boxster brakes to work?
I'm just curious though, since I never felt that my brakes were the "weak link" in the overall pacakge. Always had plenty of braking power with my stock calipers and Porterfield pads.
But then again, its been a while since I was on a track on a hot day...
slivel
post May 16 2005, 03:23 PM
To fit the Boxster brakes you need to start with struts that have a 3.5 inch bolt spacing. I have 911 RSR struts and used to have Carerra calipers. The kit is a simple bolt on from this point. It takes all of about an hour to do both sides. There is an adapter block of aluminum that bolts to the strut and the caliper bolts to the adapter.
Aaron Cox
post May 16 2005, 03:25 PM
yep. new calipers are axial mount.
why dont they make an adapterr block for 3" spacing struts? (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif)
Mueller
post May 16 2005, 03:29 PM
914 Freak!
QUOTE (Aaron Cox @ May 16 2005, 02:25 PM)
good question and one I have never seen answered (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif)
it must have something to do with the offset of the caliper centerline and the strut mounting ears being too close??????
Aaron Cox
post May 16 2005, 03:32 PM
someone makes an adapter for 3" to 3.5" to run S calipers etc.....
so that has been solved i guess...
Mueller
post May 16 2005, 03:35 PM
914 Freak!
QUOTE (Aaron Cox @ May 16 2005, 02:32 PM)
really???
never heard of it nor seen it, can you dig up a picture??
I know there is at least one member here that has a set of "S" calipers that he'd like to run......
Aaron Cox
post May 16 2005, 03:40 PM
on the thread...slivel started a week or 3 ago... someone posted the link or the name of the people who make 3" to 3.5" caliper adapters....
AA
nocones
post May 16 2005, 04:02 PM
Sportscar lunatic
What is the spacing on the "M" calipers?
Mueller
post May 16 2005, 04:21 PM
914 Freak!
QUOTE (nocones @ May 16 2005, 03:02 PM)
3"
the other spacing is 3.5" for the later 911 suspensions...not sure what year.....possibly 84 and newer??? anyone???
the 944 turbos used an oddball spacing which is 3.75 I believe....
Mueller
post May 16 2005, 04:22 PM
914 Freak!
QUOTE (Aaron Cox @ May 16 2005, 02:40 PM)
AA
aaron, I couldn't find it...i did find a thread, but it was about adapters using the Boxster calipers again....
Aaron Cox
post May 16 2005, 06:12 PM
QUOTE (Mueller @ May 16 2005, 03:21 PM)
3"
early S cars with konis had 3.5" spacing.
1974 is when they all went to 3.5" (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
and mike. ill look for the thread, someone listed it.
xitspd
post May 16 2005, 06:51 PM
Marv,
Picture attached is a 993 TT front caliper and rotor with a 17 inch rim.
Dan
- Lo-Fi Version Time is now: 2nd April 2026 - 09:24 AM
