Is the Dustless blaster safe to use on Rims, Fuchs or Mahle |
flmont |
Jul 21 2017, 05:49 PM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
Since Iam getting the engine bay blasted would it be safe to do the rims too,..if its done at a distance,..?? Thanks Frank
mepstein |
Jul 21 2017, 06:15 PM
914-6 GT in waiting Group: Members Posts: 19,313 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
It should be good but remember, it will remove paint but not the anodizing.
flmont |
Jul 21 2017, 06:18 PM
Ahh Ok,.Thanks
Mark Henry |
Jul 21 2017, 07:49 PM
See the start of this thread on how to remove the anodizing.
http://www.914world.com/bbs2/index.php?showtopic=191978 Many people trying to do a DIY polish job have damaged their rims by over sanding the rims without removing the anodizing first. At a car show last weekend I saw a set of hearts that were destroyed this way by some yahoo. |
jmitro |
Jul 22 2017, 06:20 AM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
does it depend on the type of blast media used? IE sand vs glass vs walnut shells?
If none of those remove the anodizing then it would make my job easy (IMG:style_emoticons/default/smile.gif) |
mepstein |
Jul 22 2017, 07:05 AM
does it depend on the type of blast media used? IE sand vs glass vs walnut shells? If none of those remove the anodizing then it would make my job easy (IMG:style_emoticons/default/smile.gif) Walnut won't remove anodizing. Sand will - don't sandblast wheels! Glass might. Sometimes the anodizing is failing anyway. I glass beaded cookies but the finish was already compromised. |
moorepower |
Jul 22 2017, 09:11 AM
Member Group: Members Posts: 55 Joined: 9-May 15 From: eastern Nebraska Member No.: 18,718 Region Association: Upper MidWest |
does it depend on the type of blast media used? IE sand vs glass vs walnut shells? If none of those remove the anodizing then it would make my job easy (IMG:style_emoticons/default/smile.gif) Walnut won't remove anodizing. Sand will - don't sandblast wheels! Glass might. Sometimes the anodizing is failing anyway. I glass beaded cookies but the finish was already compromised. Plastic media will remove paint frome a Coke can, and not damage the aluminum. |
Mark Henry |
Jul 22 2017, 09:32 AM
The stripping I showed in the link is real easy, hardest part is finding a big enough tray.
Care must be taken as it is corrosive and never mix with ammonia (poison gas), but the solution is biodegradable, just put it on your lawn and wash it down with a bunch of water. |
Lo-Fi Version | Time is now: 8th June 2024 - 01:17 PM |
