probably stupid question or two, fuel pump relocation |
hndyhrr |
Jul 26 2017, 08:21 PM
Senior Member Group: Members Posts: 555 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest |
bbrock |
Jul 26 2017, 08:27 PM
I'm not sure how to get those off, but you can buy either the exact same thing or very similar through McMaster-Carr fairly cheaply. Search for anti vibration mounts or something similar.
GeorgeRud |
Jul 26 2017, 08:31 PM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
There's a nut on the other side of the sheet metal, but if it's stuck, just leave them. These rubber mounts are widely available so new ones wouldn't be a bad idea.
Spoke |
Jul 27 2017, 05:57 AM
Jerry Group: Members Posts: 6,991 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Also when buying wire to extend the electric wire do i need to buy a bigger gauge wire than what is connected to fuel pump electric plug, to accommodate the longer run? I ran 16ga extension cord type cable purchased at Home Depot; worked fine in my car. A resistance calculator on Cirrus Systems online gives 0.04 ohm for 10 foot of 16ga wire. If you run pos and ground, that would be 0.08 ohm. Ground can be local chassis ground requiring only one wire. Assuming 5 amperes for the motor, the voltage drop on a single wire 16ga is 0.4V and should be negligible in operation. 12ga wire will cut the voltage drop in half. |
Spoke |
Jul 27 2017, 06:02 AM
I didn't have the rubber isolators from the original configuration so I made my own with rubber connectors from Home Depot for connecting different size PVC and some hose clamps.
Attached image(s) |
cary |
Jul 27 2017, 08:42 AM
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
Give the nuts on the backside an overnight dose of PB Blaster.
Might break them lose, but usually not. Vice grips on the rubber side. Make sure you get a bite on the plate. If the nut doesnt budge either snap off the stud or leave them there and buy ones. My .02c for the am. BTDT |
Lo-Fi Version | Time is now: 8th June 2024 - 03:10 AM |
