sixaddict |
Senior Member ![]() ![]() ![]() Group: Members Posts: 808 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States ![]() ![]() |
I was talking to a non Porsche engine building /machine shop yesterday and he told me new oil formulation regulations means we need to add zinc additive in older cars
Any one out there have knowledge ( versus opinion) on this. I use Brad Penn but he seemed to indicate this is industry wide. He was not trying to sell me anything |
Biggles |
Member ![]() ![]() Group: Members Posts: 191 Joined: 5-September 13 From: UK Member No.: 16,353 Region Association: England ![]() |
I was talking to a non Porsche engine building /machine shop yesterday and he told me new oil formulation regulations means we need to add zinc additive in older cars Any one out there have knowledge ( versus opinion) on this. I use Brad Penn but he seemed to indicate this is industry wide. He was not trying to sell me anything this issue has been around for a few years now. You can put a zoinc booster additive (ZDDP) in the engine, but you really need to look for an oil with high levels of zinc in it already. its been discussed on World before so do a search. |
Biggles |
I was talking to a non Porsche engine building /machine shop yesterday and he told me new oil formulation regulations means we need to add zinc additive in older cars Any one out there have knowledge ( versus opinion) on this. I use Brad Penn but he seemed to indicate this is industry wide. He was not trying to sell me anything this issue has been around for a few years now. You can put a zinc booster additive (ZDDP) in the engine, but you really need to look for an oil with high levels of zinc in it already. its been discussed on World before so do a search. |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Just look for oils in the 1100-1500 ppm range.
Which one to use is a can of personal taste worms with a pinch of hype. I use a diesel oil that's cheap enough to change often. |
Tom_T |
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California ![]() ![]() |
IIRC one of the Brad Penn oil lines has ZPPD in it for older cars, Porsche also sells their branded oil for classic Porsches with their recco'd amount of ZPPD, & if those 2 are too expensive then there are a classic/older car oil blend by most of the major oil brands at the local FLAPS, Wallymart, etc. with the amount in the same range as the Porsche recco/product.
I don't know the ZPPD ppm recco off-hand, so can't say if Mark Henry's is what Porsche would recco. IIRC #2 if you had valve seats hardened in a rebuild, then the ZPPD may not be necessary, but IMHO the ZPPD will still protect the other internal parts which were designed to function in the days of the old school oil with ZPPD in it. Those who are running the modern synthetic oils may be causing problems with their classic car engines of all types (assuming still as originally engineered parts) due to the lack of ZPPD, according to my longtime factory trained 914 mechanic & others I know. As others have said, there a a bunch of past threads on here about this subject, but you'll find it easier to do a google search for it, rather than this site's search function. (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
I use Valvoline VR-1 racing oil.
It has ZDDP but you have to look carefully at the label and get the right one. |
sixaddict |
thanks for insights
snakemain |
Ronin Member ![]() ![]() ![]() Group: Members Posts: 577 Joined: 14-January 10 From: Aviano, Italy Member No.: 11,232 Region Association: None ![]() ![]() |
The pro who rebuilt my engine filled it with Shell Rotella. Seems to be fine so far.
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,325 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
GeorgeRud |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest ![]() |
I'd heard that even Rotella had changed formulations though it was a go to oil for many. Besides valves, the cam lobes need the ZDDP in flat tappet engines. It's also best to use an oil with appropriate ZDDP levels rather than trying to blend your own with additives.
larryM |
emoze ![]() ![]() ![]() Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California ![]() ![]() |
everything you ever wanted to know - here Ultimate Motor Oil Thread or Why we hate CJ4/SM oils http://forums.pelicanparts.com/porsche-911...j4-sm-oils.html - suggest you start at the latest (last) posts & work back we don't need to reinvent this discussion (IMG:style_emoticons/default/piratenanner.gif) |
bbrock |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains ![]() ![]() |
everything you ever wanted to know - here Ultimate Motor Oil Thread or Why we hate CJ4/SM oils http://forums.pelicanparts.com/porsche-911...j4-sm-oils.html - suggest you start at the latest (last) posts & work back we don't need to reinvent this discussion (IMG:style_emoticons/default/piratenanner.gif) Didn't read all 105 pages of that thread (IMG:style_emoticons/default/blink.gif) But I've read a fair amount about the ZDDP issue and I'm curious what you smart guys think about these posts suggesting the ZDDP thing may be overblown: http://pedrosboard.com/read.php?7,30533,30536 http://www.nonlintec.com/sprite/oil_myths.pdf http://www.chevelles.com/forums/13-perform...-more-oils.html I don't know what to think. I see a lot of discussion on many forums about the importance of ZDDP for classic engines, but very little hard data. And I'd like to know more about whether newer anti-wear additives like molybdenum and titanium compensate for reduced ZDDP. It's a confusing topic for a simple consumer. |
mepstein |
I just follow what most of the best Porsche engine builders in the business recommend. Understanding and hard data are secondary.
Mark Henry |
I'd heard that even Rotella had changed formulations though it was a go to oil for many. Besides valves, the cam lobes need the ZDDP in flat tappet engines. It's also best to use an oil with appropriate ZDDP levels rather than trying to blend your own with additives. Yes, but Rotilla is still up there in the good zone. I use Chevron Delo 400 15w40, another similar dino diesel oil with about the same levels as the old RotillaT . Delo is the oil Henry at Supertec recommends. One thing about running the cheaper diesel oil is it's not near as expensive as some of the bouquet oil's. Thus you are more likely to change your oil often, which is just as important as which oil you use. BTW I don't recommend Delo in the thinner grades, for some reason they have a different additive package by my research. |
jkb944t |
Member ![]() ![]() Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None ![]() |
Mark Henry |
The pro who rebuilt my engine filled it with Shell Rotella. Seems to be fine so far. We use rotella t. Cheap enough and has the right stuff in it. Which Shell Rotella do you use? Jeff B I would assume Mark's shop uses the original dino (pic below). I've also used T6 and like it, but it's synthetic, so never use it on a new engine till break in is complete and synthetics have been known to make leaks in aircooleds worse. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.ruralking.com-26-1501503284.1.jpg) |
michael7810 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,081 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region ![]() ![]() |
The pro who rebuilt my engine filled it with Shell Rotella. Seems to be fine so far. We use rotella t. Cheap enough and has the right stuff in it. Which Shell Rotella do you use? Jeff B I would assume Mark's shop uses the original dino (pic below). I've also used T6 and like it, but it's synthetic, so never use it on a new engine till break in is complete and synthetics have been known to make leaks in aircooleds worse. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.ruralking.com-26-1501503284.1.jpg) Does it come in 20-50. I couldn't find it on the website |
Mark Henry |
Al Meredith |
Senior Member ![]() ![]() ![]() Group: Members Posts: 961 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 ![]() |
Go to the L&N Engineering website and you should get a commentary from Charles on the ZDDP issue and aircooled engines. Joe Gibbs now "Driven" been using it for years.
Lo-Fi Version | Time is now: 17th June 2024 - 06:01 AM |
