LED Bulbs source, Everything 'crept headlights |
jim_hoyland |
Jul 31 2017, 02:46 PM
Get that VIN ? Group: Members Posts: 9,314 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I want to directly replace the dual function rear Red brake light and white back up light
Looking for a source t |
clapeza |
Jul 31 2017, 03:03 PM
Member Group: Members Posts: 229 Joined: 7-February 11 From: South GA Member No.: 12,677 Region Association: South East States |
I want to directly replace the dual function rear Red brake light and white back up light Looking for a source t Here ya go: https://www.spokeworksled.com/914-led-solutions Quality product, and one of our own, here on the World. |
bandjoey |
Jul 31 2017, 03:31 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Chris914n6 |
Jul 31 2017, 07:20 PM
Jackstands are my life. Group: Members Posts: 3,328 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
I have a pair of these, not installed yet of course as I wanted to do an action vid (IMG:style_emoticons/default/biggrin.gif)
Philips 1157 LED |
jim_hoyland |
Jul 31 2017, 08:33 PM
I have a pair of these, not installed yet of course as I wanted to do an action vid (IMG:style_emoticons/default/biggrin.gif) Philips 1157 LED Thanks; I put in an order for a pair |
Mikey914 |
Aug 1 2017, 01:06 AM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Remember you will need to change out the relay to solid state, or it will click 2x as fast. (IMG:style_emoticons/default/biggrin.gif)
Spoke |
Aug 1 2017, 04:44 AM
Jerry Group: Members Posts: 6,989 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Remember you will need to change out the relay to solid state, or it will click 2x as fast. (IMG:style_emoticons/default/biggrin.gif) Most OEM flashers will hyperflash (2x rate) when going to LED turnsignals. The 914 flasher does not hyperflash with LED turnsignals as it has a secondary function to flash at a normal rate for the master cylinder brake warning switch and the e-brake switch. What does happen with the 914 flasher with LED turnsignals is the tachometer turnsignal indicators will not work correctly and the effect is different between the L + R indicators in the early cars (70-73) or single L/R indicator in the later cars. For later cars with single L/R indicator, the only solution is EP26 flasher available at most FLAPS but it is not a panacea. EP26 by Novita does not power the C2 lead which drives the L/R indicator. Therefore EP26 must be modified to power C2. I provide this modification on my website listed earlier. This fix is not perfect. When the MC warning switch or e-brake is pulled, the tach L/R indicator will flash. For early cars with separate L and R tach indicators, the 914 flasher will flash at the normal rate but will not power the "K" lead which drives the center tap of the L and R tach indicators. Thus both L and R will flash at the same time at a reduced intensity. Weirder yet is as the desired L or R turnsignals are flashing, the L and R tach indicators will provide power to the opposite turnsignal thus providing what I call "ghosting" as the opposite turnsignal may slightly flash as well. There are 2 solutions for early cars: 1) Replace flasher with EP26. Since EP26 doesn't power the K/C2 lead, these must be modified to drive the K/C2 lead. I provide these on my website. 2) Use standard 914 flasher and make a "Y" pigtail to drive the common wire between the L and R tach indicators to tie this point to ground. Simply tape off the center tap wire from the flasher. |
rothaus |
Aug 1 2017, 11:06 AM
Member Group: Members Posts: 119 Joined: 20-November 10 From: Virginia Member No.: 12,404 Region Association: None |
Check out these
http://www.914world.com/bbs2/index.php?showtopic=286608 Or direct to carmagic.us Cheers Engelbert |
Mikey914 |
Aug 1 2017, 11:47 AM
Bulbs are not an issue I sell the dash and inst lights the tail light s are 1156 and 1157 you can buy at superbrightleds.com and I stock them too.
No shortage of places to buy. |
jim_hoyland |
Aug 1 2017, 11:54 AM
Mikey914 |
Aug 1 2017, 12:50 PM
Bulbs are not an issue I sell the dash and inst lights the tail light s are 1156 and 1157 you can buy at superbrightleds.com and I stock them too. No shortage of places to buy. Thanks ;couldn't find them on the web site On my super secret listing but for you Jim I can get you a set. (IMG:style_emoticons/default/biggrin.gif) Actually need to list I'll work on getting these up for all for Fridays big GB blowout |
Lo-Fi Version | Time is now: 1st June 2024 - 08:53 PM |
