dh_berman |
Newbie ![]() Group: Members Posts: 11 Joined: 31-July 17 From: Boston, MA Member No.: 21,305 Region Association: None ![]() |
I just purchase a 1970 914-6 race car. The seating position is such that when I move the seat close enough to reach the pedals, the steering wheel is way to close. The steering wheel is removable with a momo hub adapter like this
http://www.pelicanparts.com/catalog/shopca...mowhel_pg26.htm Any suggestion how to move the steering wheel further forward? I need to move it about 6 inches. Thanks |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,316 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Remove the adaptor and use a 380mm early Porsche 914 wheel.
Racer |
Senior Member ![]() ![]() ![]() Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region ![]() |
I just purchase a 1970 914-6 race car. The seating position is such that when I move the seat close enough to reach the pedals, the steering wheel is way to close. The steering wheel is removable with a momo hub adapter like this http://www.pelicanparts.com/catalog/shopca...mowhel_pg26.htm Any suggestion how to move the steering wheel further forward? I need to move it about 6 inches. Thanks A pic of your setup would help us see the issue... Is the wheel "flat" or is it "dished" ? How close is "too" close? Does the wheel have a quick release feature or is it just a smaller diameter aftermarket wheel? |
dh_berman |
I just purchase a 1970 914-6 race car. The seating position is such that when I move the seat close enough to reach the pedals, the steering wheel is way to close. The steering wheel is removable with a momo hub adapter like this http://www.pelicanparts.com/catalog/shopca...mowhel_pg26.htm Any suggestion how to move the steering wheel further forward? I need to move it about 6 inches. Thanks A pic of your setup would help us see the issue... Is the wheel "flat" or is it "dished" ? How close is "too" close? Does the wheel have a quick release feature or is it just a smaller diameter aftermarket wheel? I mentioned above that it is about 6 inches too close and that it is removable. The wheel is flat. Standard momo wheel |
914forme |
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None ![]() ![]() |
A Picture really would help.
arne |
Serial Rescuer of old vehicles... ![]() ![]() ![]() Group: Members Posts: 743 Joined: 31-January 17 From: Eugene, Oregon Member No.: 20,799 Region Association: None ![]() |
Indeed. We need to see which hub and removeable adapter the car has. Text is not enough information. |
dh_berman |
dh_berman |
mankowski |
Member ![]() ![]() Group: Members Posts: 128 Joined: 7-February 10 From: Portland, Oregon Member No.: 11,335 Region Association: Pacific Northwest ![]() |
6" is a lot of distance to overcome.
It's probably not what you want to do with a racing setup but if you used the original 914 seat rails, there is an adjustable joint that tilts the angle of the seat forward and back. With the adjustment tilted backward it creates more space between the steering wheel and upper body of the driver, but without adding much if any distance between the pedals and lower body. |
GregAmy |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,311 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States ![]() ![]() |
Dude, kill the quick release (in a street car??) and see how it feels.
EDIT: nm, see it's a "race car". I don't even run a QR in my racer, plenty of space to get in and out without it. Buy hey, 'cause "race car"... |
914forme |
Ah, good look at NRG, the wheel adapter and quick release will work with the Momo, and is about the same distance as just the Momo adapter.
Thank you for the pictures. I have the NRG SRK-188H and the SRK-650BK Not installed yet it is for my EG project that is using a 911 column. |
dh_berman |
Thanks 914forme. That's very helpful.
dh_berman |
914forme - The NRG website doesn't indicate that the hub you mention will fit a 1970 914. It starts with 79-83 911. Do you know that it will fit? Thanks
914forme |
914forme |
If you want to go shorter, the NGR short hub adapter is about as close as you can go.
mepstein |
914, 914-6 & early 911 columns all have the same spline count. Promise.
mepstein |
ablesnead |
Member ![]() ![]() Group: Members Posts: 157 Joined: 16-September 13 From: United States Member No.: 16,395 Region Association: None ![]() |
They make a billet short adapter , just for these situations , check ebay for available fitments..if not ,spline end and bolt circle can be cut and welded fairly close from any billet mount , not and expensive proposition
914forme |
914, 914-6 & early 911 columns all have the same spline count. Promise. Hmmm (IMG:style_emoticons/default/confused24.gif) I thought they where different, oh well thanks Mark |
mepstein |
914, 914-6 & early 911 columns all have the same spline count. Promise. Hmmm (IMG:style_emoticons/default/confused24.gif) I thought they where different, oh well thanks Mark The early 911 guys like our 914 wheels for the smaller diameter. Any early 914 wheel (ends in a 10) is a perfect, bolt on fit. You just need to remove the plastic hub and bolt on a 911 cancel ring. Porsche used a 914-6 wheel to make the thick wrapped 911RS wheel. Later wheels, (72 on, end in 11) have the same spline count and the fit is good but not perfect (chamfer is different) and you need to drill and tap holes for cancel ring. |
Lo-Fi Version | Time is now: 10th June 2024 - 10:04 AM |
