fuel in the oil, Fuel in the oil |
Graham du Toit |
Aug 2 2017, 11:04 AM
Newbie Group: Members Posts: 1 Joined: 18-June 17 From: Amanzimtoti South Africa Member No.: 21,194 Region Association: None |
Good evening from South Africa.
I have a 1970 914 that runs on weber carbs. I have had the carbs serviced and have changed all the fuel lines. I however find that I am getting fuel in the oil and it appears there is a fuel leak between the head and the sleeves. What coud be the cause of this? Thanks in advance Graham |
stevend914 |
Aug 2 2017, 02:46 PM
Member Group: Members Posts: 376 Joined: 13-December 16 From: Saint Louis Member No.: 20,670 Region Association: Upper MidWest |
Good evening from South Africa. I have a 1970 914 that runs on weber carbs. I have had the carbs serviced and have changed all the fuel lines. I however find that I am getting fuel in the oil and it appears there is a fuel leak between the head and the sleeves. What coud be the cause of this? Thanks in advance Graham Can't answer your question, however, back in '79-'80 I lived in Kinross and owned a 914. Orange, might have been a '71. |
Mikey914 |
Aug 2 2017, 02:48 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I'm curious. Only explanation I could guess is too rich???
bdstone914 |
Aug 2 2017, 02:49 PM
bdstone914 Group: Members Posts: 4,529 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Good evening from South Africa. I have a 1970 914 that runs on weber carbs. I have had the carbs serviced and have changed all the fuel lines. I however find that I am getting fuel in the oil and it appears there is a fuel leak between the head and the sleeves. What coud be the cause of this? Thanks in advance Graham Turn the ignition on and look down the carbs and see if you have fuel over flowing down the venturis. Floats not set correctly or bad neddle valve could cause flooding. Change the oil. |
Elliot Cannon |
Aug 2 2017, 03:09 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
(IMG:style_emoticons/default/agree.gif) Even after servicing, the carb floats could be stuck. It can happen on re-assembly. What you're describing is a very rich fuel mixture and/or raw fuel flowing directly into the intake manifold. Even after servicing, the carb floats could be stuck. It can happen on re-assembly. What you're describing is a very rich fuel mixture and/or raw fuel flowing directly into the intake manifold. Change the oil.
anderssj |
Aug 2 2017, 03:15 PM
Dog is my copilot... Group: Members Posts: 1,662 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region |
I had a similar problem with dual Dell carbs a few years back--floats had started to hold gasoline (so they no longer floated as designed), also bad (sticking) needle valves. Accelerator pump diaphragms were leaking too, though those were secondary sources of the leaks.
burton73 |
Aug 2 2017, 05:18 PM
burton73 Group: Members Posts: 3,538 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Gas in the oil will kill your engine. The lubricating properties of the oil go to shit after it gets flooded with gas. I had that happen to me in my Second 911 Porsche and then I got the dreaded rod nock. Yep, change the oil.
Bob B |
r_towle |
Aug 19 2017, 09:02 AM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Floats set wrong, needle valve is dirty
Lo-Fi Version | Time is now: 1st June 2024 - 04:44 AM |
