Heat barrier and sound deadening material. |
daytona |
Aug 2 2017, 02:45 PM
daytona Group: Members Posts: 437 Joined: 13-April 14 From: Ormond Beach, Florida Member No.: 17,249 Region Association: South East States |
Hi Guys,
I am about ready to start working on the interior of the 914 and am trying to decide if I should use Dynamat or some other material on the inside of the firewall and the floor. Any recommendations are appreciated? Thanks, Bill. |
Mocrow |
Aug 2 2017, 03:28 PM
Newbie Group: Members Posts: 1 Joined: 12-June 17 From: Mo Member No.: 21,171 Region Association: South East States |
I have used the Reflectix insulation purchased from Lowes on two auto restorations. It worked great and have had zero problems.
Garland |
Aug 2 2017, 04:21 PM
Restoration Fanatic Group: Members Posts: 1,329 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
I used Fat-Matt, and EZ-Cool on my build-off car. Heres the link to the build page at that point.
Michigan Build Deux |
effutuo101 |
Aug 2 2017, 05:48 PM
Advanced Member Group: Members Posts: 2,735 Joined: 10-April 05 From: Lemon Grove Member No.: 3,914 Region Association: Southern California |
I used Lizard Skin. No results as I am still trying to get the car off of jack stands.
Blue6 |
Aug 2 2017, 06:11 PM
Senior Member Group: Members Posts: 1,037 Joined: 3-October 13 From: SoCal Member No.: 16,470 Region Association: Southern California |
Bill,
I used Dynamet on the firewall, but it's pricey. On the rest of the interior, I used the Lowes/Home depot stuff. Works great for under the carpet. I also removed the door panels and lined the inside of the doors. That made the biggest noise reduction. |
Wyvern |
Aug 2 2017, 06:49 PM
Member Group: Members Posts: 324 Joined: 7-October 15 From: San Francisco (East Bay) Member No.: 19,245 Region Association: Northern California |
I used the Reflectix product inside the engine compartment as well .
Mark Henry |
Aug 2 2017, 07:02 PM
I know it's heavy but I just reused the factory firewall mats. in the cab the factory rubbrerized mat can't be any heavier than fatt-mat or brown bread mat.
The bay side I'm not worried about rust, there was none and my teen is rarely in the rain. I can see replacing it if you want a bit of weight savings. Haven't decided what I'm going to use on the floors yet. EZcool is a closed cell foam, do a search and you'll find that CC foam doesn't absorb much sound. |
doug_b_928 |
Aug 2 2017, 07:56 PM
Senior Member Group: Members Posts: 692 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada |
For the floors, is there something that can be used that works well enough and does not glue/get stuck in position? I don't want to have to remove the tar again someday and would like to be able to pull the carpet back and check on the floors once in a while. I recall reading somewhere that Dynamat and the like are difficult to remove, but I could be misremembering.
moorepower |
Aug 3 2017, 09:48 AM
Member Group: Members Posts: 55 Joined: 9-May 15 From: eastern Nebraska Member No.: 18,718 Region Association: Upper MidWest |
Kaowool ceramic paper is VERY light and a far better insulator than anything listed.
jd74914 |
Aug 3 2017, 12:32 PM
Its alive Group: Members Posts: 4,782 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Kaowool ceramic paper is VERY light and a far better insulator than anything listed. I have a hard time believing it wears well since it pulls apart relatively easily. It's also itchy and doesn't withstand water very well. It's awesome stuff-I use it all of the time for insulating test burners, but IMHO poorly suited to an automotive application. |
914dave |
Aug 3 2017, 12:44 PM
914 Addict Group: Members Posts: 703 Joined: 19-October 03 From: Willow Grove Pa. Member No.: 1,262 Region Association: North East States |
I would not recommend Eastwood sound deadening material. I got it cheap because of damaged boxes at the store. It bleeds everywhere! I may rip it out. Bleeding thru the perlon carpet on the back pad. I haven't even been out on the road yet. Here's a picture of it pooling by the footwell. Look at the runs above the pedal cluster I secured it with their recommended roller.
Montreal914 |
Aug 3 2017, 12:59 PM
Senior Member Group: Members Posts: 1,588 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
I would not recommend Eastwood sound deadening material. I got it cheap because of damaged boxes at the store. It bleeds everywhere! I may rip it out. Bleeding thru the perlon carpet on the back pad. I haven't even been out on the road yet. Here's a picture of it pooling by the footwell. Look at the runs above the pedal cluster I secured it with their recommended roller. (IMG:style_emoticons/default/blink.gif) thanks for the tip, sorry (IMG:style_emoticons/default/sad.gif) |
jmitro |
Aug 3 2017, 05:05 PM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
I would not recommend Eastwood sound deadening material. I got it cheap because of damaged boxes at the store. It bleeds everywhere! I may rip it out. Bleeding thru the perlon carpet on the back pad. I haven't even been out on the road yet. Here's a picture of it pooling by the footwell. good to know! Eastwood products seem to be hit or miss; some great, some horrible. |
daytona |
Aug 3 2017, 07:11 PM
Thank you to all for the replies and suggestions. Now I got to make a decision.
Bill. |
Elliot Cannon |
Aug 3 2017, 07:22 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
I really like Dynamat and have used it extensively in my car. It does a great job. It sounds like and feels just like you are driving a 44 year old German air cooled sports car. (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/laugh.gif)
Chris914n6 |
Aug 4 2017, 02:04 PM
Jackstands are my life. Group: Members Posts: 3,336 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
I can't tell the difference between Lowes Peel-n-Seal and the stuff put on by the factory, so I've been using it. Cheap and easy to get.
Strategically when I put new speakers in the PartsFinder. Really helped with the lower frequencies and rattles. (IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.staticflickr.com-431-1501877055.1.jpg) Also did the HB project. Overkill for sound but there was lots of heat transferring thru the firewall and floor. Hoping it also helps with the driveline noise thru the rear cab wall. (IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.staticflickr.com-431-1501877056.2.jpg) The Dynamat on the doors has been there a long time. It didn't stick all that well and sagged in places where it wasn't pressed on by the door panel. It's hard now and falling off. Getting replaced with the PnS. For non-sticky stuff you want mass loaded vinyl. Basically the stock stuff on the inside of the firewall/behind the rear pad. |
914dave |
Aug 10 2017, 12:38 PM
A follow up to my submission on the Eastwood sound deadener. I sent Eastwood a picture that I posted in this thread. They were extremely apologetic and sent me new material and cleaning supplies. I was going to push my luck and ask that they send someone to scrape all the old out. But they did what they could to make good on the product. It's sitting on my front porch now. Hope it's not melting in the sun. Hahaha
Localboy808 |
Aug 10 2017, 09:41 PM
Member Group: Members Posts: 185 Joined: 17-July 16 From: Palmdale, Ca Member No.: 20,194 Region Association: None |
FatMat for me ordered off Amazon. The stuff from Lowe's seems very good too. And affordable.
Lo-Fi Version | Time is now: 8th June 2024 - 07:29 PM |
