Side Shifter cup bushing, - press on to console lever? |
Kansas 914 |
Aug 5 2017, 09:28 AM
Advanced Member Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains |
Should the white bushing located in the side shift transmission end press on to the rod or simply reside in the housing.
The pictures I have seen it appears to be pressed on the lever. Mine is pushed back in the housing. Thanks in advance! |
Kansas 914 |
Aug 5 2017, 10:39 AM
I pulled the housing and the cup does snap on to the shifter selector lever coming from the shift console.
Mark Henry |
Normal.
It might get stuck in there as it gets older, but that's typical and nothing to worry about. |
ndfrigi |
Aug 5 2017, 10:40 AM
Advanced Member Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
ooops edited: Sir Mike, my experienced with it after around 8x replacing/removing that part, the bushing will come in and out of the small lever. But the bushing cannot easily be remove from the knockle (round end from the console lever). Meaning you have to push in or press in the bushing to the knockle first. Hope it helps you!
Kansas 914 |
Normal. It might get stuck in there as it gets older, but that's typical and nothing to worry bout. Thanks Mark - I installed a new one from 914Rubber. I should be good for another 40 years! (IMG:style_emoticons/default/smile.gif) |
Kansas 914 |
Aug 5 2017, 10:42 AM
Sir Mike, my experienced with it after around 8x replacing/removing that part, the bushing will come in and out of the transmission console lever. But the bushing cannot easily be remove from the knockle (round end of the long lever). Meaning you have to push in or press in the bushing to the knockle first. Hope it helps you! Thanks Noel - I am buttoning it up now. |
ndfrigi |
Aug 5 2017, 10:44 AM
Sir Mike, my experienced with it after around 8x replacing/removing that part, the bushing will come in and out of the transmission console lever. But the bushing cannot easily be remove from the knockle (round end of the long lever). Meaning you have to push in or press in the bushing to the knockle first. Hope it helps you! Thanks Noel - I am buttoning it up now. sorry my bad, edited my 1st message. |
Mikey914 |
Aug 5 2017, 11:43 AM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I know there's another thread on this but...
Got these on sale for $1.99 This weekend only. http://shop.914rubber.com/91142413900-Ball...m?categoryId=-1 (IMG:style_emoticons/default/MDB2.gif) Attached thumbnail(s) |
Kansas 914 |
Aug 5 2017, 12:30 PM
I know there's another thread on this but... Got these on sale for $1.99 This weekend only. (IMG:style_emoticons/default/MDB2.gif) Thanks Mark - I have one in my Shopping Cart - I will push the buy button before the weekend is over. Lots of other goodies too - cheers! |
Lo-Fi Version | Time is now: 8th June 2024 - 07:07 AM |
