sdoolin |
Member ![]() ![]() Group: Members Posts: 363 Joined: 1-May 14 From: LouKY Member No.: 17,299 Region Association: None ![]() |
Wanting to get my suddenly spare 2.0l off the floor and onto my engine stand. Having trouble finding studs/bolts of correct size to thread into the bottom 2 mounting holes (threaded into the cases)?
Anyone know this off the top of their head? The threads are slightly munged up, so I will chase them with a tap if I can determine the size. |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
M10mm X 1.50
sdoolin |
Thanks so much...
JFG |
Senior Member ![]() ![]() ![]() Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None ![]() |
Did you remove these studs? Only asking as these lower 2 studs on mine are about 5_7mm too short. Was thinking about splicing and welding an extension onto them but if they unscrew that would be a bonus.
Mark Henry |
Lo-Fi Version | Time is now: 17th June 2024 - 02:19 PM |
