Headlight Motor Wiring, What goes where? |
7TPorsh |
Aug 8 2017, 09:11 PM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
My driver's side all of a sudden stopped popping up. Passenger side works.
If I manually crank it up, it will go down when the switch turns off but wont pop up when on. All the lights work. When I started looking at the wires a couple of the connection opened and now I.m not sure what connects to what. I have 2 hot wires that seem to have been connected to each other. I used google and site search. No luck. Does anyone have a schematic of just this isolated area? I found some diagrams but they don't indicate what color wires. Need to know which wire coming off the motor goes where.... |
7TPorsh |
Nov 8 2017, 01:13 PM
Bumping this up again. Still have this issue. Is there any easy diagram anywhere that shows what color wire goes where? All the diagrams I see just show lines but dont say what color the wires are and where they go....
mepstein |
Nov 8 2017, 01:25 PM
914-6 GT in waiting Group: Members Posts: 19,305 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
switch the headlight relays and see if it makes a difference.
for $20, you cant afford not to have it. https://www.ebay.com/itm/Porsche-914-1970-1...fRQ&vxp=mtr Attached image(s) |
JFG |
Nov 8 2017, 02:42 PM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
I had exactly the problem you describe, my fault was a faulty relay.
7TPorsh |
Nov 8 2017, 04:28 PM
jim_hoyland |
Nov 9 2017, 05:58 PM
Get that VIN ? Group: Members Posts: 9,313 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Are the small diodes still connected ? I just went through this. Look on the outer side of the HL motor; see the black coverings ? The diodes is inside that black piece.
Look at the far left side; there maybe two-can’t remember Attached thumbnail(s) |
76-914 |
Nov 10 2017, 08:58 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Are the small diodes still connected ? I just went through this. Look on the outer side of the HL motor; see the black coverings ? The diodes is inside that black piece. Look at the far left side; there maybe two-can’t remember (IMG:style_emoticons/default/agree.gif) IIRC, Mike Bellis has a link or some info in his signature re: head light wiring. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 31st May 2024 - 06:51 PM |
