Fuchs sizes for standard 914, wheel sizes |
toronto914 |
May 18 2005, 11:18 AM
Newbie Group: Members Posts: 6 Joined: 12-April 05 From: tORONTO oNTARIO Member No.: 3,924 |
What 5 bolt sized fuchs can I put on a standard 914(without fender flares) if I use the 5 bolt adapters.
Thanks for your help, KS |
Mueller |
May 18 2005, 11:35 AM
"maybe", 15x6 or a 16x6 with a 195 width tire for a bone stock rear fendered car.........those running that size rim should be able to tell you if they have an inch between the tire and the fender on the rear (I doubt it)...no problems on the front...it's the rear that gets tricky
some people claim a 23mm offset 7" rim works on the rear of stock fendered car (I don't believe them (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) ) the adapters (which are frowned upon) are normally about 1" thick see the chart below (yes, there is a 15x7 rim that would work with the adapters, but those sell for about $500 each or more if and when you can find them) (IMG:http://www.914world.com/bbs2/uploads/post-2-1116277852.jpg) |
skline |
May 18 2005, 11:36 AM
Born to Drive Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California |
If you could find a 14 inch you could run them with the skinniest tires you will find and it may fit. The adapter pushing it out further and you wont get much of a tire under there.
lapuwali |
May 18 2005, 12:30 PM
Not another one! Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
With adapters, I can't say. If you go 5-lug the "right way", you can comfortably fit 6x15 Fuchs under the fenders. My first 914 had this setup. Clearance was pretty snug on the right-hand rear fender, but fine everywhere else. It had 195/60 tires on it, but I think 205/50 tires would fit with only very minor work on one or both rear fenders (they're almost never symmetrical).
If you go with 6x15 wheels, make sure you get the ones with the 911 part number, not the 901 part number. You can tell them apart easily, as the 901 parts cost 2x as much. No good reason for this, just concours weenies requiring absolute authenticity. |
retrotech |
May 18 2005, 12:39 PM
retrotech Group: Members Posts: 470 Joined: 2-November 03 From: Mosier, Oregon Member No.: 1,302 |
I have a just refinsihed set of 14", done with Black centers, new black, painted caps. Anyone?
Please PM to me. Thanks |
toronto914 |
May 18 2005, 01:08 PM
Thanks for all of these points guys.
KS |
Lo-Fi Version | Time is now: 10th June 2024 - 03:58 AM |
