> Grinding down shock tower for more neg camber, anyone have pics or tips?
nebreitling
post May 18 2005, 05:40 PM
Member Emeritus
i'm doing better and better, but i know i can go faster.
at the AX on saturday, demick and i were shooting tire temps. just as i thought, my fronts were significantly hotter on the outside than the inside. i don't remember the exact numbers (though IIRC they ranged from 80-95 deg F), but the disparity was significant enough that i'd like to dial in more neg. camber.
i know that a few people grind down the shock tower in front -- before i go cutting, i'm just curious if anyone has any "after" photos of this mod...
thanks (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) n
Replies(1 - 19)
ArtechnikA
post May 18 2005, 06:32 PM
rich herzog
gack; if it's what you've gotta do, i understand, just seems a lot of work...
Elephant has camber-offset ball joints, and WEVO has monoball upper strut bearing mounts that permit lots more negative camber without tub mods...
but - do what you've gotta...
nebreitling
post May 18 2005, 08:45 PM
Member Emeritus
thanks, rich
i'll look into these as options... curious what other people have...
who owns rob ways car now? i know that he did this to his AX 914
Brad Roberts
post May 18 2005, 09:05 PM
914 Freak!
Chung owns it.. and I cut it. Bring the car up to Yeamans TONIGHT and I'll cut it.
You have NO idea what you are getting into.. (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) You cant "just" move the strut inside. You'll need to remove the dust covers for the shocks... reset toe.. measure camber...
I would imagine it can be done with a hacksaw.. but it takes 15-20 minutes with a die grinder.
B
nebreitling
post May 18 2005, 09:24 PM
Member Emeritus
i'll stop by, we'll talk. if it's too much, that's fine...
n
Brad Roberts
post May 18 2005, 09:44 PM
914 Freak!
I need to make a "Fry's" run, but I'll LEAVE Andy here.
B
post May 18 2005, 09:47 PM
Resident German
QUOTE (Brad Roberts @ May 18 2005, 08:44 PM)
but I'll Andy here.
nice english, dude ...
yupp, got pizza and beer!
(IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) Andy
asdfgsadgsd
Brad Roberts
post May 18 2005, 09:51 PM
914 Freak!
Nathan,
Do you want any pizza ??
B
scotty914
post May 18 2005, 09:57 PM
suby torque rules
i have a thought on how to get more camber and make it look stock. if i am not wrong if you do any mods for more camber it can bump you up in class, or at least can count towards a bump in class.
to show what i mean i would need a pic from straight down on the shock top area on the fender. the mod i am thinking would work would be cutting the top of the shock tower in an oval shape around the holes. with the holes being offset from center. then switching the part from pass to drivers side and vic versa. then welding it back in, then grind the welds smooth. this would place the holes closer to the center line of the car but if the welding was done right it would look stock.
there would be now way a tech would show that the holes where relocated like grinding the holes does.
J P Stein
post May 18 2005, 09:58 PM
Irrelevant old fart
I went to a lot of time, $$ & effort to get -2 up front.
Now I gotta undo it. My new tiars like -.8 or so.
Problem: I don't have room on the pass side front.. tire to fender...to let it out.
Gonna wait till next winter to booger up my new paint job there.
E. Fry
post May 20 2005, 12:54 PM
Another thing that you will run into if you cut away what you really need is that the upper strut mount will come into contact with the body on the inboard side of the strut tower. To solve this you can cut away a narrow section of the inboard side of the strut mount and restructure where you cut away. All this will leave a visible void on the outboard side of the strut tower top. I haven't done it, but I have seen it done. More to ponder.
anthony
post May 20 2005, 01:06 PM
2270 club
QUOTE (scott thacher @ May 18 2005, 08:57 PM)
Wouldn't that be cheating? I mean what's the point of cheating for club AX. How can you feel good if you win?
cha914
post May 20 2005, 01:16 PM
MUSR 8 - 5lug conversion done wed - drive 500miles thrus
"There are cheaters and there are losers" thats what I have always been told about racing...
(IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif) all in good fun (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif)
ottox914
post May 20 2005, 01:52 PM
The glory that once was.
J.P.- those are the same camber plates I've got- see my post on adding plates, losing ground. What all did you need to do to get to -2.0, and what tires are you running now that don't need all that much camber?
Downunderman
post May 20 2005, 02:30 PM
Region Association: Australia and New Zealand
The neatest way to get some more neg is to set both top mounts to the middle position, measure the camber, then pull the legs out. Take the brakes and hubs off, pull the inserts out of the leg, put it in a vise and then bend the leg the desired amount. You need a big tip on the torch to heat just above the stub axle. You can calculate the bend you need and measure it with a staight edge on the caliper mounting face to the top of the strut. Let cool repaint, reassemble.
Korijo
post May 20 2005, 02:46 PM
[]D o [] o []V[] o []D
good one (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
URY914
post May 20 2005, 02:50 PM
Piece of cake.
scotty914
post May 20 2005, 05:46 PM
suby torque rules
although not as slick as bending here is my way
if you cut an oval shape out of the tower with the center shifted to the center of the car, then took the section cut out and swaped it side for side on the car and welded it back it the holes whould be un modified. the oval on the pic is a poor example of where you would have to cut but it should give you an idea. the red lines show how much you would gain by swaping side to side. if you cut it 1/2 inch torwards the center you would gain 1/2 inch of adjustment.
i hope you can see what i mean with the pic
Joe Ricard
post May 20 2005, 06:21 PM
CUMONIWANNARACEU
You can do anything you want to your car scott. You would be in SCCA Prepared class anyway with your SUBY motor.
If you do this method to a car you had better be a real artist with a welder AND GRINDER.
ArtechnikA
post May 20 2005, 06:24 PM
rich herzog
QUOTE (Joe Ricard @ May 20 2005, 08:21 PM)
prepared!?
engine swaps move you straight to Modified AFAIK ...
(they did, times - and rulebooks - change...)
- Lo-Fi Version Time is now: 16th March 2026 - 03:40 AM
