| germaneighter |
Aug 23 2017, 08:46 PM
Member ![]() ![]() Group: Members Posts: 130 Joined: 9-August 05 From: Tulsa, OK Member No.: 4,563 |
It's been a long time since I've posted on this site. My '74 is in long term storage mode, waiting for me to retire. A year or so ago I picked-up a 1972 2.4 long block motor at an estate sale for $200. I immediately disassembled the motor to determine if there were any catastrophic issues. (no serious issues seen) It has been disassembled since last year.
My question - will letting the motor set in this condition indefinably cause any issues? I keep it misted with oil and covered. thanks |
| porschetub |
Aug 23 2017, 09:03 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,081 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Should be fine ,my 2.2 was wrapped in shrinkwrap for 17yrs but I turned the flywheel every month or so,put it in my conversion and fired up straight away,but you need to check it over before running,chain tension ,rockers ,valve clearance install chain savers and plenty of gaskets and seals externally etc .
These are a good motor and can make good power,enough for a 914 . |
| mepstein |
Aug 24 2017, 05:39 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,634 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
You are good.
| mountainroads |
Aug 24 2017, 08:47 AM
Member ![]() ![]() Group: Members Posts: 210 Joined: 19-February 12 From: Seattle Member No.: 14,145 Region Association: Pacific Northwest |
A year or so ago I picked-up a 1972 2.4 long block motor at an estate sale for $200. I had to read your post 3 times to make sure I was reading correctly. A 1972 2.4 (6) long block for two hundred bucks??? Was this a Corvair motor (IMG:style_emoticons/default/smile.gif) and if not, where can I find one of those?? As others have said - you should be good with periodic misting and turning. - MR |
Lo-Fi Version | Time is now: 17th April 2026 - 01:56 AM |
