tires and wheels, What will fit? |
motley_crew_2004 |
May 19 2005, 10:35 PM
Newbie Group: Members Posts: 1 Joined: 19-May 05 From: Kalispell, MT Member No.: 4,107 |
I am converting my 914 front suspension over to 911 suspension, and simply drilling out my back rotors, but does anyone know what size of tires and wheels will still work under stock fenders and what type of offset the rims will have?
Thanks for the help. |
Trekkor |
May 19 2005, 10:46 PM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
205/50/15 with 4.75" backspace.
I run 4" backspace, with *agressive* fender rolling. KT |
Mueller |
May 19 2005, 11:22 PM
Trek, it helps if you mention how wide your rims are (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) motley_crew_2004, the 914 is an oddball, you can fit wider rims/tires up front than the rear....generally on a stock fendered car, 23mm offset 7" wide rims can be run on the rear with 205's if you roll the fender lips a little....some people claim no mods had been done to their car to get them to fit...each car is a little different a near perfect fit for the rear is a 7" rim with a 35mm offset and a 205 tire....if you go aftermarket, Revolution can supply these (see vendor section) or you can get a set of 7" rims from an 1987 and new Porsche which will have a deeper offset, a spacer might be needed to move the rim out a little so that it does not rub against the inside trunk wall in the rear....if you look at yesterdays thread about the Boxster rims, you can see some pictures and get some more info on offsets... Welcome to the club !!!! |
Trekkor |
May 19 2005, 11:47 PM
Good point, 5.5" Westerns KT Attached image(s) |
DanT |
May 20 2005, 11:18 AM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
Two ideas and I will give you as much info as I can remember.
#1 My good buddy used to run 7 inch phone dials from a 944 with big spacers and longer wheel studs on a stock bodied 914-6 front and rear with 205s #2 I ran 7 inch Fuchs early 911 rear offset on the rear of my 914-6 with 225s and stock body work. Also ran my 914-6 with 6 inch Fuchs 911 offset front and rear with 205s under stock body work. Lots of combinations out there. (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) Remember that there is such a large variation in body fitment on 914s that what will work on one car won't on another. I had a 70 1.7 years ago with 5.5 fuchs that fit great with 205s, took them off and put them on my 74 2.0 and had to use spacers in the rear...so you never know. ( rubbed on the inside of body work not on fender lips) |
ottox914 |
May 20 2005, 12:13 PM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
What will work for you may not for me, and vice versa. 205 50 hoosiers on 5.5 fuchs rub in the inside, 205 50 azenis on 5.5 mahles do not. car was on the allignment rack today- with the hoosiers on it- you could SEE about 1/8" difference in the distance from the inside sidewall of the tire to the inside fender/trunk area from one side to the other. And yes, the chassis is spot on square and all 4 wheels allign easily. go figure.
AZ914 |
May 20 2005, 04:40 PM
914 Dumbass Group: Members Posts: 1,459 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region |
Motley,
I just have a street car... I'm rollin' stock 911 Fuchs rims, 16x6's all around with Yokohama AV/ES 100's - 205/55 ZR16s and they fit fine without rolling. You could probably fit 215's.. Also, the rolling diameter is almost right on with the stock 914 165/75-15 size so my speedo/odo are real close. |
Lo-Fi Version | Time is now: 9th June 2024 - 01:02 PM |
