KEP Clutch and/or Pressure Pate, Your opions |
mmichalik |
Sep 11 2017, 06:39 PM
MikeM Group: Members Posts: 700 Joined: 27-January 16 From: Valley Center, CA Member No.: 19,600 Region Association: Southern California |
Hi Everyone,
I have a question about clutch replacement. I'm just about ready to purchase a clutch kit (Pressure plate, clutch disk, release bearing, etc) and someone had mentioned that Kennedy Engineering Products made some good stuff. But before I do a bunch of research on them, I thought I would ask if anyone has used them before in your 914? If so, what opinions do you have about them. Are they worth looking into or should I stay with the tried and true Sachs equipment. Thanks, Mike |
Chris914n6 |
Sep 11 2017, 07:08 PM
Jackstands are my life. Group: Members Posts: 3,328 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
KEP makes good stuff.
But the first question is what engine do you have? Sachs works fine on a stockish motor and is probably less moola. |
mmichalik |
Sep 11 2017, 07:45 PM
The car is a 2.0 but, I lost the motor.... long story unfortunately. So, I had a 1910 (Big Bore 1800) built with a cam and dual 40's.
I'm not going to be autocrossing or anything like that, Just a driver for the mountains and a couple of days a week sort of thing. |
porschetub |
Sep 11 2017, 07:57 PM
Advanced Member Group: Members Posts: 4,703 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
The car is a 2.0 but, I lost the motor.... long story unfortunately. So, I had a 1910 (Big Bore 1800) built with a cam and dual 40's. I'm not going to be autocrossing or anything like that, Just a driver for the mountains and a couple of days a week sort of thing. No stick with stock Saches,plenty strong enough,using that with my "6" conversion and it works fine...shop around as prices go all over the place,if your pressure plate is ok you can second life it,you then need to replace the disk only and the thrust bearing as required. Make sure your flywheel surface is good or get it machined, replace all wear parts on clutch release are @ the same time...this is important. You will be good. |
Larmo63 |
Sep 11 2017, 08:16 PM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
eBay has some pretty cheap complete packages, that's what I bought for my /4. |
mmichalik |
Sep 12 2017, 08:45 AM
Thanks for the replies, gentlemen.
I will stick with Saches. Mike |
Lo-Fi Version | Time is now: 29th May 2024 - 03:58 AM |
