Master cylinder reservoir line attachment, Master cylinder 1972 |
Porsche Guy |
Sep 14 2017, 03:24 PM
Newbie Group: Members Posts: 1 Joined: 30-August 17 From: Connecticut Member No.: 21,391 Region Association: North East States |
Anybody have a good method to attach / insert into the grommets the 2 reservoir feed lines to the master cylinder while on the car? Thank you.
BeatNavy |
Sep 14 2017, 06:15 PM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
Anybody have a good method to attach / insert into the grommets the 2 reservoir feed lines to the master cylinder while on the car? Thank you. I'm not aware of a good way to do it with the MC still mounted. I'd recommend dismounting the MC and installing the feed lines to it first (then attaching to the reservoir). You need those little metal washers, and you definitely want those lines to seat or they will leak. As you probably know by now, getting those lines seated firmly is a bit of a PITA. Dismounting the MC is really not that difficult. Good luck, and (IMG:style_emoticons/default/icon_bump.gif) in case someone else has a better idea. |
era vulgaris |
Sep 15 2017, 06:34 AM
J is for Genius Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
I did this about 4 years ago when I replaced the MC on my first 914. I don't remember exactly how I got the lines to seat into the MC because my memory of it all is a bit of a blur from several hours of frustration and swearing at the car (IMG:style_emoticons/default/biggrin.gif)
As BeatNavy mentioned, it helps to keep the MC unmounted. |
BeatNavy |
Sep 15 2017, 06:58 AM
Oh, one thing I should have mentioned previously. Do some searching here on the site about "bench bleeding" the MC and bleeding the brakes in general. Bleeding the brakes on our cars can sometimes be tricky and frustrating, particularly with a brand new MC.
theer |
Sep 15 2017, 07:31 AM
Senior Member Group: Members Posts: 677 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
(IMG:style_emoticons/default/agree.gif) Bleeding the brakes is an often frustrating, multi-step process. Lots of guidance here, though.
Pushing the pipes in the grommets is tough, but was slightly easier when the MC was not yet mounted to the firewall - gives you a little more room. Also, make sure to lubricate the grommets liberally with brake fluid. Good luck! |
cary |
Sep 15 2017, 07:33 AM
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
I just did it on Matt's car. I wish I'd shot a picture of the hose orientation for you.
You need to get them kind of started I right direction before you put it back up in there. I use NAPA Sil Glyde to get the stoppers lubed up. Then I slide the flared end of the metal pipe in so it rests right above the last rim inside the stopper. This allows it to be soft enough to move around. I kind of get one side started at an angle, them push it in. This is all done with the MC in a bench top vise. I did learn something while Matt's car was on the lift at Rothsport. Jeff called it exercising the rear e brake calipers. Basically you pump out each piston, then push it back in. You leave one pad in. Remove the other pad and insert and a medium screw driver. Pump the pad out till it meets up to the screwdriver, the push it back in. Repeat on the other side. Jeff thought we'd need to retract the piston with the adjuster, but it pushed back in. |
cary |
Sep 15 2017, 07:35 AM
Lo-Fi Version | Time is now: 9th June 2024 - 07:40 PM |
