QUOTE(Porsche Guy @ Sep 14 2017, 05:24 PM)
Anybody have a good method to attach / insert into the grommets the 2 reservoir feed lines to the master cylinder while on the car? Thank you.
I'm not aware of a good way to do it with the MC still mounted. I'd recommend dismounting the MC and installing the feed lines to it first (then attaching to the reservoir). You need those little metal washers, and you definitely want those lines to seat or they will leak. As you probably know by now, getting those lines seated firmly is a bit of a PITA. Dismounting the MC is really not that difficult.
Good luck, and
in case someone else has a better idea.
