Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
Found this on the TWM throttle body website....
not only is it for the linkage, it also doubles up as a common manifold for MAP readings for fuel injection.... Attached image(s) ![]() |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
just a bell crank linkage... WITH GOODIES (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
im sure you could make it mike read something about, how they arent so greeat on a horiz. opposed aircooled motor, because of the expansion of the motor.... thats why most hex bar setups 'self center' themselves with springs on each end |
Mueller |
i figure the expansion of the motor would play games with it...Jake mentioned figures of .010 to .030 for a superheated motor....
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,688 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
another problem with this setup, the movement of the throttle blades won't be linear!
in fact, it'll be a copped off SIN Curve ... i'm not sure what that does to your rpm/hp/torque graph ... (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) Andy |
Aaron Cox |
it would play games with your head
1" of pedal is 30% throttle, but 1.5" is 80 percent for a crude example |
Mueller |
an oblong or cam shaped wheel could be used instead (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
maf914 |
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None ![]() ![]() |
Or increase the diameter of the wheel and locate the two linkage arms at the sides as opposed to the top and bottom as shown so that movement will be at near right angles or tangent to the wheel. The same problem occurs with the typical cross bar linkage and the solution or compromise is the same. (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
jhadler |
Long term tinkerer... ![]() ![]() ![]() Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 ![]() |
Hey Mike (and anyone else interested)...
Have you bought the throttles yet? If so, where from? If not, I found a source of TWM throttles that is WAAAY cheaper than TWM directly. Just ordered a set of 45's this week... The pony car shops are always the place to look for cheap go-fast parts... -Josh2 |
Mueller |
yep....paid $125 for mine, they include the injectors and the TPS (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) of course they won't "bolt" right on without a little bit of work: (1200 Ninja throttle bodies) (IMG:http://www.914world.com/bbs2/uploads/post-2-1106337182.jpg) |
Lo-Fi Version | Time is now: 16th June 2024 - 03:20 PM |
