LED light question |
haasman |
Sep 24 2017, 09:34 PM
Newbie Group: Members Posts: 30 Joined: 19-January 09 From: United States Member No.: 9,947 Region Association: Northern California |
Installed LED bulbs in my 70 914-6. Really like their brightness. Especially these days when drivers tend to brake only after seeing a third high mounted brake light of modern cars.
I installed yellow LEDs for the rear turn signals and when operating, yellow comes through the red taillight lenses! Unexpected surprise. Used red LED for the brake lights and wow, do they pop. My question- in the front after installing yellow LED bulbs, when using a right turn-signal the left bulb also glows, though not as bright. Left turn signal works great and the right one doesn't indicate anything. With 4-way hazard lights, all operate properly. I systematically checked the grounds at each light housing. Any ideas/suggestions? Haasman |
rothaus |
Sep 25 2017, 02:55 AM
Member Group: Members Posts: 119 Joined: 20-November 10 From: Virginia Member No.: 12,404 Region Association: None |
Installed LED bulbs in my 70 914-6. Really like their brightness. Especially these days when drivers tend to brake only after seeing a third high mounted brake light of modern cars. I installed yellow LEDs for the rear turn signals and when operating, yellow comes through the red taillight lenses! Unexpected surprise. Used red LED for the brake lights and wow, do they pop. My question- in the front after installing yellow LED bulbs, when using a right turn-signal the left bulb also glows, though not as bright. Left turn signal works great and the right one doesn't indicate anything. With 4-way hazard lights, all operate properly. I systematically checked the grounds at each light housing. Any ideas/suggestions? Haasman Did you check if it does the same with the old bulbs, on the front turning signal ? Cheers Engelbert |
Olympic 914 |
Sep 25 2017, 05:42 AM
Group: Members Posts: 1,676 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
I had the same problem when I installed my LED lights. I was getting a "ghost" flash on both sides.
you make a Y piece and install it as shown here. > http://www.914world.com/bbs2/index.php?sho...=272915&hl= That should solve your problem. |
jim_hoyland |
Sep 25 2017, 05:50 AM
Get that VIN ? Group: Members Posts: 9,319 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Whch bulbs did you use on the rears ? Vendor site ?
haasman |
Sep 25 2017, 10:17 AM
haasman |
Sep 25 2017, 10:21 AM
Thank you for this solution. Will check it out this weekend.
I had the same problem when I installed my LED lights. I was getting a "ghost" flash on both sides. you make a Y piece and install it as shown here. > http://www.914world.com/bbs2/index.php?sho...=272915&hl= That should solve your problem. |
Spoke |
Sep 25 2017, 03:19 PM
Jerry Group: Members Posts: 6,991 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I bought them off of eBay- Super LED or www.superbrightleds.com Its been a while but I beleive I installed the 1156-CW18-T Cool White and 1157-A18-T Amber You'll have more efficient light output if you match the LED color to the lens color. LEDs in particular have very narrow wavelength output thus much of their light output may be filtered out by a lens of the wrong color. The bulbs listed above are white (1156 rear turnsignal?) and amber (1157 front turnsignal and brakes?). Although you do mention using red LEDs for the brakes. About the ghosting, likely your tachometer turnsignal indicators are flashing together. The series connection of the tach indicators is powering the opposite side's turnsignal. The Y-pigtail on the tach is an easy mod. Send me a PM if you have any questions. |
Lo-Fi Version | Time is now: 9th June 2024 - 04:31 PM |
