| bandjoey |
Sep 30 2017, 10:31 PM
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,935 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Got a new set of door stop rollers from Mikey 914 rubber to install and naturally while in in there...
Have a spray can of teflon grease. Yellow sticky goo. Have another spray can of silicon chain lube. What's best for both door handles inside and outside? For the locking rods? For the door stay rollers? The window track and gears (late doors)? Do you use something else than what I've got? ...and why can't both dooor stay rollers be metal? It's a thought. |
| mepstein |
Oct 1 2017, 05:55 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,961 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
I use bicycle chain lube. Just a little bit. More than that and it just gets dirty faster.
| Mikey914 |
Oct 1 2017, 07:49 AM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,785 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Got a new set of door stop rollers from Mikey 914 rubber to install and naturally while in in there... Have a spray can of teflon grease. Yellow sticky goo. Have another spray can of silicon chain lube. What's best for both door handles inside and outside? For the locking rods? For the door stay rollers? The window track and gears (late doors)? Do you use something else than what I've got? ...and why can't both door stay rollers be metal? It's a thought. They can. I made these exactly like factory. I also do the 911 door stay kit. There are a few other differences, but it utilizes a aluminum roller for both. The main difference is that the 914 they cut costs everywhere they could. I can turn you an aluminum version if you want the cost is $2 more. Just me know. I may just do up a bunch and maybe have an option on these. Yes, bike chain grease works well. Mark |
| Andyrew |
Oct 1 2017, 03:47 PM
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,381 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California
I use white litheum on all my cars, typically apply it at the end of the rainy season on all the hinges.
| bandjoey |
Oct 1 2017, 05:09 PM
So I disassembled the door stay completely. Decreased all the parts. Install the new rollers. I can see why the black nylon wears out. It does not roll. Even greasing the sides and bearing surface of that roller pin it's a very tight fit into the metal framework The arm of the doors stay simply slides on that nylon and it never moves.
Wouldn't it be better if that roller rolled? |
| rjames |
Oct 1 2017, 05:26 PM
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,483 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest
| 914_teener |
Oct 1 2017, 06:34 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,270 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
I use white litheum on all my cars, typically apply it at the end of the rainy season on all the hinges. (IMG:style_emoticons/default/agree.gif) I do the same. You can get a tube at the local Home Depot. |
| Andyrew |
Oct 1 2017, 06:43 PM
I use white litheum on all my cars, typically apply it at the end of the rainy season on all the hinges. (IMG:style_emoticons/default/agree.gif) I do the same. You can get a tube at the local Home Depot. I get the stuff in a can and spray it on, then wipe up the residu with a towel. |
| ledfoot |
Oct 1 2017, 06:57 PM
Member ![]() ![]() Group: Members Posts: 54 Joined: 14-February 06 From: Dayton,OH Member No.: 5,581 Region Association: None
Wurth HHS-plus work very well and will not attract the dust.
Lo-Fi Version | Time is now: 30th October 2026 - 12:14 PM |
